since version 1.47, all files newly copied to the vault have an incorrect timestamp (time of copying instead of the original timestamp of the file). after downgrading to v1.46, there were no timestamp issues
OS: Windows 10 x64 Version 1803, Dokany used
Thanks for reporting! I can only verify this when you move a file into the vault.
When you perform a copy operation, the timestamp is preserved.
strangely, any file I copy or move to the vault then has the wrong timestamp (time of copying instead of original date of change)
i opened an issue for this on the bug tracker: https://github.com/cryptomator/cryptomator/issues/867
I can confirm that the bug was resolved in v1.4.11-rc1
Any file that I copy or move to the vault now has the correct timestamp.
