On a Samsung Galaxy S6 running Android 7 with latest version of Dropbox app (86.2.2). Cryptomator version is 1.3.0.
When I attempted to view the files in my vault, I get the generic error message “an error occurred”. No files are listed.
I first tried to delete the vault and add it again but I get the same error upon typing in the vault unlock passphrase. I then removed the app, installed the app again, added the vault but there was no change when after typing in the passphrase. I just get that unhelpful error message.
Any ideas why? The desktop Cryptomator app has no problems accessing the vault.
If you press “Send log file” in the settings, your mail app should be opened with a new mail and all necessary flags set (like the mail address: support@cryptomator.org).
I have sent the log.zip as requested. It will be coming from my GMail account (joe.kang@gmail.com).
I should note that in trying to get the error to happen again, Cryptomator has “magically” been able to access my vault. I am no longer seeing the “an error occurred” message.
I am going to restart my phone to see if the problem has truly gone away or not.
I hope you’re able to see something in the debug log that I have sent.
Thank you very much and yes, we found something: java.lang.IllegalArgumentException: com.google.b.b.a$d: Unrecognized character: c
All encrypted files are stored Base32 encoded. We don’t know why but the API from Dropbox (which we use to access their cloud) are retrieving a very small amount of files with lowercase characters even when they should be case insensitive what is with the sync clients verifiable and which are created with uppercase characters: https://www.dropbox.com/developers/documentation/http/documentation
Case insensitivity
Like Dropbox itself, the Dropbox API is case-insensitive, meaning that /A/B/c.txt is the same file as /a/b/C.txt and is the same file as /a/B/c.txt.
This is a bug in the Dropbox API, we will create an issue in their repository for this problem
