Archive decrypted files using Acronis True Image
I would like to use Acronis True Image to archive the decrypted data (virtual drive), but ATIH2020 does not see the drive. Is there any way to do this? Winzip Pro does work on the decrypted files, but ATIH doesn’t see the folders.
Hi. please make sure that cryptomator and Acronis do use the same user.
You may also try to mount your vault as a folder instead of a drive.
(mounting as folder allows, accesing your vault as an elevated/different user.)
more information: Cryptomator on Windows: Accessing your vault with admin priviliges
