unfortunately I could no longer open my safe.
Then I tried to import the backup file. Unfortunately I got the following error. But I still have the actual vault file.
What should I do now?
Can I still save my data?
java.nio.file.FileSystemAlreadyExistsException
at org.cryptomator.cryptofs.CryptoFileSystems.lambda$create$0(CryptoFileSystems.java:49)
at org.cryptomator.common.vaults.Vault.createCryptoFileSystem(Vault.java:121)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:138)
