In Cryptomator version 1.4.2, Windows 10, 64 bits, an option when opening a vault allows you to select a Custom Mount Point rather than a Drive Letter.
I can’t figure out how to use a Custom Mount Point. When I provide a name (like ‘Fred’) the mount fails.
What is the proper syntax for a mount point name and can you provide an example?
How can mount point files be accessed from applications or .bat files? What is the proper syntax?
Cheers and Thanks.
Chris.
