I upgraded my vault without any error Messages. All Files where local.
When I open my vault it’s completely empty. The encrypted Files are still there. But Cryptomator isn’t showing them.
I tried installing the older version again but that is showing me now that the Password is wrong and that is definitely not the case.
What can I do to fix this?
You can not go back to an earlier version of cryptomator after upgrading to 1.5 It changes the structure of your encrypted vault, which 1.4 can not understand.
What operating system are you running and cryptomator version did you use to upgrade?
Do you know what file system type your cryptomator vault is on? (eg NTFS, FAT, EXT4)
I would recommend a “clean” install of cryptomator and dokan , especially since you tried downgrading to 1.4. Dokan requires reboots to fully remove /enable it, so i’d suggest the following.
Uninstall cryptomator
Uninstall dokan driver
Reboot system
Install the latest cryptomator 1.5 with the included dokan driver
reboot again before using.
Check the cryptomator options is set for dokan (not webdav)
try unlocking your vault.
Hopefully this will sort it, but If its still empty a debug log might help.
I managed to solve it.
I looks like the masterkey file wasn’t upgraded correctly.
After restoring the old Masterkey that was used before the Upgrade I could open it correctly.
Thanks for the help anyways.
I have the same problem. After installing Cryptomator on a new computer, I selected the key file and it said it had to update the format, which I allowed. After that, the opened folder is empty! I see that a backup was automatically created. However, copying the automatically created backup file to “masterkey.cryptomator” doesn’t fix it – the vault is still empty.
Fortunately I happen to still be logged in to it on another computer and have downloaded and saved all the files. But this is totally unacceptable: to force a reformat that loses all the files!
Update: I can at least still open the vault from (yet) another computer, still running the earlier version. But I can’t access the files from the new computer where the vault looks empty. What’s the solution?
Thanks! I’ve installed Cryptomator at least 8 times, probably more. I didn’t notice that now we have to go to Dokany and install it separately, or else I never needed to before. (Good luck for non-computer-savvy people figuring out where to find the dokany installer in github!)
