Advice to resolve file conflict in vault
I am using Cryptomator and the syncing the vaults on OneDrive. I have Vault which I have not modified for a few days now.
I have now just booted up my 2nd PC and after the sync process of OneDrive, I now have a file conflict.
I am unsure what I should do or how to resolve this in order to avoid any file corruption or disappearance.
Any tips or advice what to do now.
Cheers
Sync conflicts can happen in cloud storages (e.g., OneDrive in your case) for several reasons. Cryptomator is able to detect sync conflicts and will show you the conflicted file with a “(Conflict XYZ)” at the end.
In that case, it’s your decision what to do with it. I would check both files manually and decide which one I’d like to keep. If your conclusion is that both are identical, you can delete one copy. But that’s all in your hands how you’d like to organize your files.
