Please describe exactly what your problem is. What you are doing, what the system behaves like, what you expect that should happen, maybe error messages from the logging
With the given information I can only assume you are searching for the WebDAV URL of your nextcloud webdav interface.
I tried the following on my android device. Maybe the terms ar not correct, because i am using a German version and i didn’t find a language switch.
Add a existing vault
[click] WebDav
Select my WebDav
Now i see my Nextcloud Vault like the following lines:
[Folder icon] d
masterkey.cryptomator
vault.cryptomator’
Wichtig.rtf
Below folder “d” there are a lot of folders with my encrypted content
now i
Select masterkey or vault file
[click] masterkey.cryptomator
An alert pops up:
”Vault is root folder of the cloud connection
Create an new cloud connection where you select at least the parent folder of this vault folder as the root director”
Authentication fails without further notification except “Ein Fehler ist aufgetreten” / “An error occured”.
I am wondering if it is down to the missing certificate (only a self-signed one) - but in this case I’d expect a specific notification related to the missing/incorrect/untrustworthy certificate.
2FA is not enabled.
My phone runs on e/OS/ (latest version), version of Cryptomator App is 1.12.2 (obtained through F-Droid).
If you click on “Send log file” in the Cryptomator settings, it automatically should set the to address but if not, please send it to support@cryptomator.org
Stupid me! I blocked Cryptomator from accessing my local Nextcloud in RethinkDNS - and obviously forgot about that.. Allowing this connection gave me access to NC and the vault. Works flawlessly now.
