Biz
April 18, 2020, 12:01pm
1
Cryptomator Ver1.5.0
Unexpected error occurred when trying to upgrade vault in Google Drive File Stream on Windows 10.
What should I do?
Error log
java.lang.IllegalArgumentException: com.google.common.io.BaseEncoding $ DecodingException: Unrecognized character: =
at com.google.common.io.BaseEncoding.decode (BaseEncoding.java:219)
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.getNewInflatedName (FilePathMigration.java:209)
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.migrate (FilePathMigration.java:122)
at org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory (MigratingVisitor.java:55)
at org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory (MigratingVisitor.java:17)
at java.base / java.nio.file.Files.walkFileTree (Files.java:2742)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrateFileNames (Version7Migrator.java:93)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrate (Version7Migrator.java:60)
at org.cryptomator.cryptofs.migration.Migrators.migrate (Migrators.java:105)
at org.cryptomator.ui.migration.MigrationRunController.lambda $ migrate $ 2 (MigrationRunController.java:109)
at org.cryptomator.ui.common.Tasks $ TaskImpl.call (Tasks.java:139)
at javafx.concurrent.Task $ TaskCallable.call (Task.java:1425)
at java.base / java.util.concurrent.FutureTask.run (FutureTask.java:264)
at java.base / java.util.concurrent.Executors $ RunnableAdapter.call (Executors.java:515)
at java.base / java.util.concurrent.ThreadPoolExecutor.runWorker (ThreadPoolExecutor.java:1128)
at java.base / java.util.concurrent.ThreadPoolExecutor $ Worker.run (ThreadPoolExecutor.java:628)
at java.base / java.lang.Thread.run (Thread.java:834)
Caused by: com.google.common.io.BaseEncoding $ DecodingException: Unrecognized character: =
at com.google.common.io.BaseEncoding $ Alphabet.decode (BaseEncoding.java:492)
at com.google.common.io.BaseEncoding $ StandardBaseEncoding.decodeTo (BaseEncoding.java:719)
at com.google.common.io.BaseEncoding.decodeChecked (BaseEncoding.java:233)
at com.google.common.io.BaseEncoding.decode (BaseEncoding.java:217)
... 17 more
This is odd. = is the padding char which the decoder should be able to handle fine. Except for the case when it isn’t at the end of the name maybe…
Can you tell us the (ciphertext) file names of items inside the directory that this error occured in? You should be able to tell the correct directory by looking at the last message logged in the migration log before this error occured.
Biz
April 19, 2020, 5:27am
3
Thank you for your reply.
When I check the log, it seems that the process is not working well in the folder J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\.
The files in this folder have been skipped. The reason is “inflation failed.”
The following is a copy of several lines before the error occurred.
13:50:18.989 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\ESWSBCQL6XCRV45GQ3UR2M7IYU3VNBH7 (1).lng because inflation failed.
13:50:18.993 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\ESWSBCQL6XCRV45GQ3UR2M7IYU3VNBH7.lng because inflation failed.
13:50:18.996 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\GLED66BWPP2U3M44HNM23UBILTIJA65P (1).lng because inflation failed.
13:50:18.999 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\WYAM7YKPBIS4VOXJK6DRS6KEJOYLDKEE (1).lng because inflation failed.
13:50:19.000 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\WYAM7YKPBIS4VOXJK6DRS6KEJOYLDKEE.lng because inflation failed.
13:50:19.005 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\GLED66BWPP2U3M44HNM23UBILTIJA65P.lng because inflation failed.
13:50:19.011 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\7LLWRWDGLHV3VE7TPIIF2XHCNHFJXAOK (1).lng because inflation failed.
13:50:19.013 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\7LLWRWDGLHV3VE7TPIIF2XHCNHFJXAOK.lng because inflation failed.
13:50:19.018 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\3YOYFCJVUP6PZDCZQ3WUNBHLQBQSPKIT (1).lng because inflation failed.
13:50:19.019 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\3YOYFCJVUP6PZDCZQ3WUNBHLQBQSPKIT.lng because inflation failed.
13:50:19.039 [JavaFX Application Thread] ERROR o.c.u.m.MigrationRunController - Migration failed for technical reasons.
Since then, the above error has been recorded.
I guess you copied those lines from cryptomator0.log? Can you instead look at upgrade.log (in the same dir) as it is more verbose. It should contain the same ERROR message but additional lines before it.
Biz
April 19, 2020, 12:54pm
5
Is it okay with the following?
21:26:09.255 [App Background Thread 004] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\JO\4FTZS2NAIOV7PW34A7MQPWYAWHTGGI\JJYKDPIWKDPH66PZB5A27NZZGHPW6ICWGVNPDB7GQY4FE=== (1) to J:\マイドライブ\cryptBackup\d\JO\4FTZS2NAIOV7PW34A7MQPWYAWHTGGI\SnChvRZQ3n95-Q9Br7c5Md9vIFY1WvGH5oY4Ug==.c9r
21:26:09.257 [App Background Thread 004] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\JO\4FTZS2NAIOV7PW34A7MQPWYAWHTGGI\54SY7GHJSI24GQSO3TX7T7SG4M3UWU2TDHHYK3ICCRZGO=== (1) to J:\マイドライブ\cryptBackup\d\JO\4FTZS2NAIOV7PW34A7MQPWYAWHTGGI\7yWPmOmSNcNCTtzv-f5G4zdLU1MZz4VtAhRyZw==.c9r
21:26:09.363 [App Background Thread 004] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\54\5ZVN42OKZYCCDA76RGTL6LDQZQQD3O\PCHBT7RBZEKNWMZZZKFSVQGQTMONN3TVQJNCKWPEYBK23DQ7GSH2YJWY to J:\マイドライブ\cryptBackup\d\54\5ZVN42OKZYCCDA76RGTL6LDQZQQD3O\eI4Z_iHJFNszOcqLKsDQmxzW7nWCWiVZ5MBVrY4fNI-sJtg=.c9r
21:26:09.456 [App Background Thread 004] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\KK\PPFGYZPSTH37PEYJ46UI6KDTLHQJ3L\XPAGWTEPKTC4FXJC3TFUOAOK3IQYN6X7NQ2KAWCKY2NZ2QWVT37X56TWEPA5J6B5AE====== to J:\マイドライブ\cryptBackup\d\KK\PPFGYZPSTH37PEYJ46UI6KDTLHQJ3L\u8BrTI9UxcLdItzLRwHK2iGG-v9sNKBYSsabnULVnv9--nYjwdT4PQE=.c9r
21:26:09.541 [App Background Thread 004] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\E7\QSYEI5S52HS35YS5LRHTPXHO5BQXHV\HTELLYPUMYGLXSMU7ZFX2AYCYLEHHD2772ZC7D6JI4YATISGW6UV2=== to J:\マイドライブ\cryptBackup\d\E7\QSYEI5S52HS35YS5LRHTPXHO5BQXHV\PMi14fRmDLvJlP5LfQMCwshzj1_-si-PyUcwCaJGt6ld.c9r
21:26:09.622 [App Background Thread 004] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\VH\57E47KC6GGDZW2LRWTCDNFMJD34COG\5FF3EJGHFDKA3ENULCNQHOALBQO5TSYODKSTUSLN2S5KQ=== to J:\マイドライブ\cryptBackup\d\VH\57E47KC6GGDZW2LRWTCDNFMJD34COG\6UuyJMco1A2RtFibA7gLDB3Zyw4apTpJbdS6qA==.c9r
21:26:09.701 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\Q62DXA4G3B7WMIF6MCHOX5HQBSBTWJ6T.lng because inflation failed.
21:26:09.705 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\OVX3OXCSNZ4SNFVEIRUNA6YJ6F5KOIFA (1).lng because inflation failed.
21:26:09.765 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\OVX3OXCSNZ4SNFVEIRUNA6YJ6F5KOIFA.lng because inflation failed.
21:26:09.802 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\R2FNSEX6O46VUHT522NWTUWQH6G6GASB (1).lng because inflation failed.
21:26:09.946 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\R2FNSEX6O46VUHT522NWTUWQH6G6GASB.lng because inflation failed.
21:26:10.128 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\G6NWU5EDQPNHVORV2M2W23UP4E67QBQD (1).lng because inflation failed.
21:26:10.231 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\G6NWU5EDQPNHVORV2M2W23UP4E67QBQD.lng because inflation failed.
21:26:10.640 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\NJGGTUNPFMA7TXTJVQOV26WKTKM7CCIO (1).lng because inflation failed.
21:26:10.702 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\NJGGTUNPFMA7TXTJVQOV26WKTKM7CCIO.lng because inflation failed.
21:26:11.023 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\XIVLFQOXCOZOMUOPEUJZDF4KY4FB6GRN (1).lng because inflation failed.
21:26:11.024 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\XIVLFQOXCOZOMUOPEUJZDF4KY4FB6GRN.lng because inflation failed.
21:26:11.147 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\IJNGMNZBPCRCF2BEV7XHB6WTZSH5CUNW (1).lng because inflation failed.
21:26:11.168 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\IJNGMNZBPCRCF2BEV7XHB6WTZSH5CUNW.lng because inflation failed.
21:26:11.386 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\5LKZQDZX7KHGMX7CYNOGXJVYDWS6RISJ (1).lng because inflation failed.
21:26:11.487 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\5LKZQDZX7KHGMX7CYNOGXJVYDWS6RISJ.lng because inflation failed.
21:26:11.491 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\SJYHMS2RDXOJIUNVLMMYEQ7DXJKXNRVR (1).lng because inflation failed.
21:26:11.540 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\SJYHMS2RDXOJIUNVLMMYEQ7DXJKXNRVR.lng because inflation failed.
21:26:11.581 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\X3FIV64JTNV3LYCIWK6SOTJXD7DG73QQ (1).lng because inflation failed.
21:26:11.583 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\Y6FSZLXDGIMUPCPAFEFKZWEYA7LZH3ZY (1).lng because inflation failed.
21:26:11.584 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\X3FIV64JTNV3LYCIWK6SOTJXD7DG73QQ.lng because inflation failed.
21:26:11.585 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\Y6FSZLXDGIMUPCPAFEFKZWEYA7LZH3ZY.lng because inflation failed.
21:26:11.622 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\FD3T7WWS6TRDJ5UQX7AKG7K2ZGEEZRKS (1).lng because inflation failed.
21:26:11.651 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\FD3T7WWS6TRDJ5UQX7AKG7K2ZGEEZRKS.lng because inflation failed.
21:26:11.652 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\JOZKYDCKL7EJKRDSV7NMLEZWG6IN3TTN (1).lng because inflation failed.
21:26:11.684 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\JOZKYDCKL7EJKRDSV7NMLEZWG6IN3TTN.lng because inflation failed.
21:26:11.737 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\D3UPHHEAPMOEW6LHI3N45FITYY5OIFCL (1).lng because inflation failed.
21:26:11.739 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\D3UPHHEAPMOEW6LHI3N45FITYY5OIFCL.lng because inflation failed.
21:26:12.044 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\6KRPDS6J5GRBUOPISI2LIGESS2HCJ3XA (1).lng because inflation failed.
21:26:12.047 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\BT5ZZ6VWWXADZBE6WGSYEIVCLPYG7MTH (1).lng because inflation failed.
21:26:12.048 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\6KRPDS6J5GRBUOPISI2LIGESS2HCJ3XA.lng because inflation failed.
21:26:12.049 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\BT5ZZ6VWWXADZBE6WGSYEIVCLPYG7MTH.lng because inflation failed.
21:26:12.259 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\NWAS7M7QNXIJDNTPMYPNPQ6NEFT2EJTV (1).lng because inflation failed.
21:26:12.260 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\NWAS7M7QNXIJDNTPMYPNPQ6NEFT2EJTV.lng because inflation failed.
21:26:12.696 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\P22EEKT7PI7IG3W26ISHHWPZQJMUKT2A (1).lng because inflation failed.
21:26:12.697 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\P22EEKT7PI7IG3W26ISHHWPZQJMUKT2A.lng because inflation failed.
21:26:12.794 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\E2DUP33IA3U3V6LDP3WSK3W2KS7N5KBT (1).lng because inflation failed.
21:26:12.795 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\E2DUP33IA3U3V6LDP3WSK3W2KS7N5KBT.lng because inflation failed.
The last few lines.
21:26:33.630 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\VXWDI3HRVCA4IT24G6YG5MJ57BLFVWQW (1).lng because inflation failed.
21:26:33.698 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\VXWDI3HRVCA4IT24G6YG5MJ57BLFVWQW.lng because inflation failed.
21:26:33.757 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\KZEFY4ZUGTPREKPPIHQWXZWIEJB6GNGH (1).lng because inflation failed.
21:26:33.758 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\KZEFY4ZUGTPREKPPIHQWXZWIEJB6GNGH.lng because inflation failed.
21:26:33.878 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\L6HEWH65X6DDUKULOR2VO7FJYP3HQHE6 (1).lng because inflation failed.
21:26:33.878 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\L6HEWH65X6DDUKULOR2VO7FJYP3HQHE6.lng because inflation failed.
21:26:33.966 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\ESWSBCQL6XCRV45GQ3UR2M7IYU3VNBH7 (1).lng because inflation failed.
21:26:34.019 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\ESWSBCQL6XCRV45GQ3UR2M7IYU3VNBH7.lng because inflation failed.
21:26:34.044 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\GLED66BWPP2U3M44HNM23UBILTIJA65P (1).lng because inflation failed.
21:26:34.091 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\WYAM7YKPBIS4VOXJK6DRS6KEJOYLDKEE (1).lng because inflation failed.
21:26:34.092 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\WYAM7YKPBIS4VOXJK6DRS6KEJOYLDKEE.lng because inflation failed.
21:26:34.122 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\GLED66BWPP2U3M44HNM23UBILTIJA65P.lng because inflation failed.
21:26:34.239 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\7LLWRWDGLHV3VE7TPIIF2XHCNHFJXAOK (1).lng because inflation failed.
21:26:34.240 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\7LLWRWDGLHV3VE7TPIIF2XHCNHFJXAOK.lng because inflation failed.
21:26:34.370 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\3YOYFCJVUP6PZDCZQ3WUNBHLQBQSPKIT (1).lng because inflation failed.
21:26:34.371 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\3YOYFCJVUP6PZDCZQ3WUNBHLQBQSPKIT.lng because inflation failed.
21:26:34.436 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\Q62DXA4G3B7WMIF6MCHOX5HQBSBTWJ6T (1).lng because inflation failed.
Sorry, I should have made it more clear: I’m interested in the last lines before the error occured at 13:50:19.039.
Biz
April 20, 2020, 5:35am
7
In the previous post, I copied a similar error log at another time.
Below is the log from the beginning to the end of your specified time.
The beginning
13:46:19.833 [App Background Thread 090] INFO o.c.c.migration.v7.Version7Migrator - Upgrading J:\マイドライブ\cryptBackup from version 6 to version 7.
13:46:20.065 [App Background Thread 090] INFO o.c.c.migration.v7.Version7Migrator - Backed up masterkey from masterkey.cryptomator to masterkey.cryptomator.330237A2.bkup.
13:48:40.104 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\DP\ZRJT7TIVHV4QYFEXSGPO3BCDGXBMAX\JAG46VYRQNHC2GBKRJYQ5PYWL5XBWR4UGRRY6O3SD5OIO=== to J:\マイドライブ\cryptBackup\d\DP\ZRJT7TIVHV4QYFEXSGPO3BCDGXBMAX\SA3PVxGDTi0YKopxDr8WX24bR5Q0Y487ch9chw==.c9r
13:48:40.107 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\DP\OHA24GGLBISQISDFLI64I5AUU552AP\CELYA5RL2NBFXBHW53WW4HIXRXYPYZV2NCH5SIH3GDDPUM2YQFDQ==== to J:\マイドライブ\cryptBackup\d\DP\OHA24GGLBISQISDFLI64I5AUU552AP\EReAdivTQluE9u7tbh0XjfD8Zrpoj9kg-zDG-jNYgUc=.c9r
13:48:40.109 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\DP\BONWG3XKJD36AVN7DUPVMXKFO74557\MUVD44TFMLFXME7KS2DW2ATITSREWR3XLGUFNLVKJIZHFK2ZT62RU3JSF56RBOE2LFDHSVXKP4====== to J:\マイドライブ\cryptBackup\d\DP\BONWG3XKJD36AVN7DUPVMXKFO74557\ZSo-cmViy3YT6paHbQJonKJLR3dZqFauqkoycqtZn7UabTIvfRC4mllGeVbqfw==.c9r
13:48:40.113 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\DP\CFO5IP7WPIOI5PBFRCYP3FT7NNUUK6\FOJFA2GJPK3UX7UE6G53XONMQVQO7K7AWTT5Y627B65QUXA= to J:\マイドライブ\cryptBackup\d\DP\CFO5IP7WPIOI5PBFRCYP3FT7NNUUK6\K5JQaMl6t0v-hPG7u7mshWDvq-C059x7Xw-7Clw=.c9r
13:48:40.167 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\KX\O73OZT7CYLZWKGPVPSHWNY72J6P6UT\VQQK74VFZLMGYMADXY77YMR3BOVJZDPW2Q6P2ZOU5VI7O=== (1) to J:\マイドライブ\cryptBackup\d\KX\O73OZT7CYLZWKGPVPSHWNY72J6P6UT\rCCv8qXK2GwwA74__DI7C6qcjfbUPP1l1O1R9w==.c9r
13:48:40.168 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\KX\O73OZT7CYLZWKGPVPSHWNY72J6P6UT\EOMHY7RZ4X7RERW2QWUW4P3JHLDP4OSYNVGWNNOZRGVWK=== (1) to J:\マイドライブ\cryptBackup\d\KX\O73OZT7CYLZWKGPVPSHWNY72J6P6UT\I5h8fjnl_xJG2oWpbj9pOsb-OlhtTWa12YmrZQ==.c9r
Switching points between INFO and SKIP
13:48:40.449 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\54\5ZVN42OKZYCCDA76RGTL6LDQZQQD3O\PCHBT7RBZEKNWMZZZKFSVQGQTMONN3TVQJNCKWPEYBK23DQ7GSH2YJWY to J:\マイドライブ\cryptBackup\d\54\5ZVN42OKZYCCDA76RGTL6LDQZQQD3O\eI4Z_iHJFNszOcqLKsDQmxzW7nWCWiVZ5MBVrY4fNI-sJtg=.c9r
13:48:40.535 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\KK\PPFGYZPSTH37PEYJ46UI6KDTLHQJ3L\XPAGWTEPKTC4FXJC3TFUOAOK3IQYN6X7NQ2KAWCKY2NZ2QWVT37X56TWEPA5J6B5AE====== to J:\マイドライブ\cryptBackup\d\KK\PPFGYZPSTH37PEYJ46UI6KDTLHQJ3L\u8BrTI9UxcLdItzLRwHK2iGG-v9sNKBYSsabnULVnv9--nYjwdT4PQE=.c9r
13:48:40.616 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\E7\QSYEI5S52HS35YS5LRHTPXHO5BQXHV\HTELLYPUMYGLXSMU7ZFX2AYCYLEHHD2772ZC7D6JI4YATISGW6UV2=== to J:\マイドライブ\cryptBackup\d\E7\QSYEI5S52HS35YS5LRHTPXHO5BQXHV\PMi14fRmDLvJlP5LfQMCwshzj1_-si-PyUcwCaJGt6ld.c9r
13:48:40.689 [App Background Thread 090] INFO o.c.c.migration.v7.MigratingVisitor - MOVED J:\マイドライブ\cryptBackup\d\VH\57E47KC6GGDZW2LRWTCDNFMJD34COG\5FF3EJGHFDKA3ENULCNQHOALBQO5TSYODKSTUSLN2S5KQ=== to J:\マイドライブ\cryptBackup\d\VH\57E47KC6GGDZW2LRWTCDNFMJD34COG\6UuyJMco1A2RtFibA7gLDB3Zyw4apTpJbdS6qA==.c9r
13:48:40.764 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\Q62DXA4G3B7WMIF6MCHOX5HQBSBTWJ6T.lng because inflation failed.
13:48:40.767 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\OVX3OXCSNZ4SNFVEIRUNA6YJ6F5KOIFA (1).lng because inflation failed.
13:48:40.808 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\OVX3OXCSNZ4SNFVEIRUNA6YJ6F5KOIFA.lng because inflation failed.
13:48:40.813 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\R2FNSEX6O46VUHT522NWTUWQH6G6GASB (1).lng because inflation failed.
13:48:40.831 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\R2FNSEX6O46VUHT522NWTUWQH6G6GASB.lng because inflation failed.
These are the last lines.
13:50:19.024 [App Background Thread 090] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\Q62DXA4G3B7WMIF6MCHOX5HQBSBTWJ6T (1).lng because inflation failed.
The rest is the same content, only the file name is different.
The next lines follow the same log at different time because I tried it several times.
Am I seeing something strange?
Ok, I thought there would be more content in the directory in question, but anyway:
Can you post a list of the names of files inside d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU?
On a different note, can you please check if there is a directory m/WY/AM/? The Warnings about uninflatable filenames is a bit worrying.
Biz
April 20, 2020, 7:35am
9
A list of the names of files inside d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU
JOT6EXTFA6UIWOH5BCU6BLXM7JMFZFPS (1).lng
JOT6EXTFA6UIWOH5BCU6BLXM7JMFZFPS.lng
YZUBXMWS735FUBKOUH5O52PZ2DSQWHIM (1).lng
YZUBXMWS735FUBKOUH5O52PZ2DSQWHIM.lng
LKK7YWKMGCN7KKLLWSZOLYWSS6AYOVWU (1).lng
WWNGM6D55HKGAQMIJ5ZDSF4GB4V5QYQJ (1).lng
LKK7YWKMGCN7KKLLWSZOLYWSS6AYOVWU.lng
WWNGM6D55HKGAQMIJ5ZDSF4GB4V5QYQJ.lng
65YUEXG5YRCDFTXBQHKZR5FZ62D2Q2Q3 (1).lng
LMBTNF6UI23WUTCUOJ4M5QZ2V5ZIW3U6 (1).lng
LMBTNF6UI23WUTCUOJ4M5QZ2V5ZIW3U6.lng
W423EJLFY3Z4YKX2WFEWAJZTQ3D5ZDAB (1).lng
W423EJLFY3Z4YKX2WFEWAJZTQ3D5ZDAB.lng
65YUEXG5YRCDFTXBQHKZR5FZ62D2Q2Q3.lng
X6YEKX5A3VXNDLSJ2KYINLA2JDABGMEC (1).lng
X6YEKX5A3VXNDLSJ2KYINLA2JDABGMEC.lng
SS3RXWJC2NI67BJ37FWLQUXWUKMICV6M (1).lng
SS3RXWJC2NI67BJ37FWLQUXWUKMICV6M.lng
EHZEL6YE3PEFR5Z5L26AO2VLYWXXBUPB (1).lng
EHZEL6YE3PEFR5Z5L26AO2VLYWXXBUPB.lng
GB6VZJ3AO233JVNMAB3DGX5HEC7ZDKDI (1).lng
VRH53KLD5SDDULRQUJRNVZAVIJTJNVBR (1).lng
GB6VZJ3AO233JVNMAB3DGX5HEC7ZDKDI.lng
VRH53KLD5SDDULRQUJRNVZAVIJTJNVBR.lng
S4EJU3EQOQN7UUAUN53VQT3M67DAHFU2 (1).lng
S4EJU3EQOQN7UUAUN53VQT3M67DAHFU2.lng
OHMFL2OKWB3MXSFHBU4A25KF7LISZXU7 (1).lng
OHMFL2OKWB3MXSFHBU4A25KF7LISZXU7.lng
E7ADCHF3CR6MU2OZ7B5Q32SJVE6ZSSG7 (1).lng
E7ADCHF3CR6MU2OZ7B5Q32SJVE6ZSSG7.lng
2R53MGQAHIN62DD25KF3COBJ4BYP2VV7 (1).lng
2R53MGQAHIN62DD25KF3COBJ4BYP2VV7.lng
3RA4IWQCFCN26CRWK5ZFMVRQGTZJAQ5B (1).lng
3RA4IWQCFCN26CRWK5ZFMVRQGTZJAQ5B.lng
AGMHBSWOWPUHZ4KZ76UPK5LMSVAMOJKL (1).lng
AGMHBSWOWPUHZ4KZ76UPK5LMSVAMOJKL.lng
FH3ITM5I7SZUUCM3XWKDJK4XFJZEWNAR (1).lng
FH3ITM5I7SZUUCM3XWKDJK4XFJZEWNAR.lng
5Z2MBTWT7SVIKG27GRPVYRGYMBNIHCQP (1).lng
5Z2MBTWT7SVIKG27GRPVYRGYMBNIHCQP.lng
OVN2RB4QFAVHVUAXNJ5BPE3IFZ65ETQW (1).lng
OVN2RB4QFAVHVUAXNJ5BPE3IFZ65ETQW.lng
BOYHSOKWTBP3YXBPRG4DW7DNOEHKQLME (1).lng
BOYHSOKWTBP3YXBPRG4DW7DNOEHKQLME.lng
KSE2EUAAGCCNVMZZFII56Z2QITRLJZAQ (1).lng
KSE2EUAAGCCNVMZZFII56Z2QITRLJZAQ.lng
SKN44HOHBSWDVH4W3DUOT7STICSGQVFF (1).lng
NXRALA6S4E4DJO32Z6MQRRZQMMPRYN2U (1).lng
NXRALA6S4E4DJO32Z6MQRRZQMMPRYN2U.lng
SKN44HOHBSWDVH4W3DUOT7STICSGQVFF.lng
VBAZ4AXH3IPH5PO5HQNMERBNQKD3JSDV (1).lng
VBAZ4AXH3IPH5PO5HQNMERBNQKD3JSDV.lng
QPL6ASQHJMTJYYJA5247DBJJHHR2S5PL (1).lng
QPL6ASQHJMTJYYJA5247DBJJHHR2S5PL.lng
GYL3LPY6A3DBGDFPG4JABZSQMFL5MXTT (1).lng
GYL3LPY6A3DBGDFPG4JABZSQMFL5MXTT.lng
F3Y4H36UE4HIVEJR36SC7P4PNTE7VWZR (1).lng
F3Y4H36UE4HIVEJR36SC7P4PNTE7VWZR.lng
DQKRZB7DKSFFZC5WFKJD47GYJ6VOKEYR (1).lng
DQKRZB7DKSFFZC5WFKJD47GYJ6VOKEYR.lng
E64GXRXMGFN7D26GEEVSTHOKWQDXGLWV (1).lng
J4IIXFQEG65QPVD76AKANBYU6UCIPVFO (1).lng
J4IIXFQEG65QPVD76AKANBYU6UCIPVFO.lng
E64GXRXMGFN7D26GEEVSTHOKWQDXGLWV.lng
4D3YEEPXOEQJUSNE2JHU2MVS3AJET6JL (1).lng
I63VSBFRFYLAKMBH7LZZ3WHU46WWY5OF (1).lng
I63VSBFRFYLAKMBH7LZZ3WHU46WWY5OF.lng
4D3YEEPXOEQJUSNE2JHU2MVS3AJET6JL.lng
UTQVZWOBGRT5P4MYGP4RHW6NUSMMDZDX (1).lng
5XJ6JTTE2ZOFWWMQH7FLOMPSXFCN55PP (1).lng
5XJ6JTTE2ZOFWWMQH7FLOMPSXFCN55PP.lng
UTQVZWOBGRT5P4MYGP4RHW6NUSMMDZDX.lng
JNXNJVVPAHKURVKE6S4IWNPPDRZBNGZV (1).lng
JNXNJVVPAHKURVKE6S4IWNPPDRZBNGZV.lng
FMCLXLNFMYC73PLNTVAS7JTI4MK4HZS3 (1).lng
FMCLXLNFMYC73PLNTVAS7JTI4MK4HZS3.lng
6CO6OQOLFLMYA5ZOX2TUQ7YRC7UKDJ34 (1).lng
YCZJQZNQUFIP2FY7FIOGMXV6PNVMTN3C (1).lng
6CO6OQOLFLMYA5ZOX2TUQ7YRC7UKDJ34.lng
YCZJQZNQUFIP2FY7FIOGMXV6PNVMTN3C.lng
IE5EYAQJQFH64IANSJ4CNWYTTXHLPJKK (1).lng
B4FFQSGZPHOHCEZTMLO6NXIPNWNIX6KC (1).lng
B4FFQSGZPHOHCEZTMLO6NXIPNWNIX6KC.lng
IE5EYAQJQFH64IANSJ4CNWYTTXHLPJKK.lng
HYPMBMTSYAYLYLYO265447VHGTPNDARN (1).lng
3BWRHZUPW7ESNWMNYBTJDUSJLQB75Q7T (1).lng
3BWRHZUPW7ESNWMNYBTJDUSJLQB75Q7T.lng
HYPMBMTSYAYLYLYO265447VHGTPNDARN.lng
IGQWZHXONGZP5QNLUSKZS7A4ZT4UOYGS (1).lng
IGQWZHXONGZP5QNLUSKZS7A4ZT4UOYGS.lng
6CVT2LKQCD4QWVFFD5UK5W74NLGEEEEW (1).lng
6CVT2LKQCD4QWVFFD5UK5W74NLGEEEEW.lng
IYI6AJEZOEVBKSOIE2KQRO3TEQPNA7FS (1).lng
CJ7ARMZGFU5J2JEB47DY5B5HQ2NMSFA3 (1).lng
IYI6AJEZOEVBKSOIE2KQRO3TEQPNA7FS.lng
CJ7ARMZGFU5J2JEB47DY5B5HQ2NMSFA3.lng
MG2GU6U4JMHSSSGVQYVEL7OB5LSSF4CI (1).lng
MG2GU6U4JMHSSSGVQYVEL7OB5LSSF4CI.lng
GXVP5RDODGBRJANFKDYTTLN2WDFBZ2CC (1).lng
GXVP5RDODGBRJANFKDYTTLN2WDFBZ2CC.lng
WRR3Y5C46ZTFUDKMEA24MGOMMTGN5Z5L (1).lng
WRR3Y5C46ZTFUDKMEA24MGOMMTGN5Z5L.lng
BUPSPO3Z7HNPPE7LPMOHSE33YHSAUE6C (1).lng
BUPSPO3Z7HNPPE7LPMOHSE33YHSAUE6C.lng
REEGWIYYAQCERUXNUMWBO4YWZQZ42ZOU (1).lng
WKSRQMIMKWCW4GEEPW5AUZS2CSJVS4G6 (1).lng
RXYAOHR7L2HHFSAAPAWYYAEOVUXBEAZS (1).lng
GPTGOGTOOGLS4PKY3YU3BKSHYDBAIBAG (1).lng
WKSRQMIMKWCW4GEEPW5AUZS2CSJVS4G6.lng
REEGWIYYAQCERUXNUMWBO4YWZQZ42ZOU.lng
GPTGOGTOOGLS4PKY3YU3BKSHYDBAIBAG.lng
RXYAOHR7L2HHFSAAPAWYYAEOVUXBEAZS.lng
NUUL4VE3UFT3FVLQKHIGJOFOAP2XPRT4 (1).lng
TVWEZ7TZDD36XILIIESUEGPDPZLNLKRH (1).lng
NUUL4VE3UFT3FVLQKHIGJOFOAP2XPRT4.lng
TVWEZ7TZDD36XILIIESUEGPDPZLNLKRH.lng
UCZSBJMSQPHXFKQNOJW5XEUSPN7JHY4B (1).lng
6RVPZPU7FPJIH6WR5UKWUBVTQGTY5R6V (1).lng
6RVPZPU7FPJIH6WR5UKWUBVTQGTY5R6V.lng
UCZSBJMSQPHXFKQNOJW5XEUSPN7JHY4B.lng
AQHCRU7OMIRVZNHKI3FMBNFNNTLOV5EB (1).lng
4XFPVBXO6XBDBINCJ3YCHKDUDUT3MRSR (1).lng
4XFPVBXO6XBDBINCJ3YCHKDUDUT3MRSR.lng
AQHCRU7OMIRVZNHKI3FMBNFNNTLOV5EB.lng
GEQYXOX3DDVEJFPGH5GFDRNFKHQNYUJ6 (1).lng
RJAKJXA3OCLDLJDRHTIG64FCTUCYWNZC (1).lng
GEQYXOX3DDVEJFPGH5GFDRNFKHQNYUJ6.lng
RJAKJXA3OCLDLJDRHTIG64FCTUCYWNZC.lng
NZXITF6CV2IC53T7D5Q54DX2UF3WPG5I (1).lng
NZXITF6CV2IC53T7D5Q54DX2UF3WPG5I.lng
7MNDNF4DKGQHO5IZPC5OBZGEKSHYXXKH (1).lng
7MNDNF4DKGQHO5IZPC5OBZGEKSHYXXKH.lng
5F6VQKGXBWITDHHUXQ5SGHUF4I5U5AGY (1).lng
ADN46YGBUBJ42YF3BXIUS5RAADCPL7DU (1).lng
5F6VQKGXBWITDHHUXQ5SGHUF4I5U5AGY.lng
ADN46YGBUBJ42YF3BXIUS5RAADCPL7DU.lng
USLYQRNGFRSEEQHB6TNWZYBNL44JKZHB (1).lng
USLYQRNGFRSEEQHB6TNWZYBNL44JKZHB.lng
HER6ZGAGJCQ4FZ53BDXID6YF6EECLU7Z (1).lng
HER6ZGAGJCQ4FZ53BDXID6YF6EECLU7Z.lng
SPLTCWXQZMUPCUFJPNTJXHDCAM5UFCWN (1).lng
BDJ6PWQRFTBSTBBS2EHIYTXYJLXYAM72 (1).lng
BDJ6PWQRFTBSTBBS2EHIYTXYJLXYAM72.lng
SPLTCWXQZMUPCUFJPNTJXHDCAM5UFCWN.lng
44CAFIVD4YRPKSJCWG5Y5H7LXHLKKEO5 (1).lng
TD3BYTM5KCQY3SLF64CRIANPTJ4J3TAQ (1).lng
TD3BYTM5KCQY3SLF64CRIANPTJ4J3TAQ.lng
44CAFIVD4YRPKSJCWG5Y5H7LXHLKKEO5.lng
3OLGIKT5N7OBUK3W72B4WYFQ354MOAUN (1).lng
3OLGIKT5N7OBUK3W72B4WYFQ354MOAUN.lng
CFFL6JGVFNXPVG4LISOK5GSEIACTHAK2 (1).lng
CFFL6JGVFNXPVG4LISOK5GSEIACTHAK2.lng
SPWMA2WL3JXZTOIOETAF5XUJG5DJ6VRX (1).lng
SPWMA2WL3JXZTOIOETAF5XUJG5DJ6VRX.lng
TUW5CZO6R2VVZBZX75VHF2RDVZTMUL6T (1).lng
TUW5CZO6R2VVZBZX75VHF2RDVZTMUL6T.lng
3OHNMPFGX3ST7TXJ6IIX4O6HO6U3X64Q (1).lng
3OHNMPFGX3ST7TXJ6IIX4O6HO6U3X64Q.lng
6TWDT6QQDCNS76FNPVBLPYIBIAHACJ3J (1).lng
6TWDT6QQDCNS76FNPVBLPYIBIAHACJ3J.lng
CVR4ELSQNY6PTEGDTBB7OWAFIZQNXSIC (1).lng
DUWAPDJQP4VRWZQT5KPVVZDTBQCJ6T7B (1).lng
CVR4ELSQNY6PTEGDTBB7OWAFIZQNXSIC.lng
DUWAPDJQP4VRWZQT5KPVVZDTBQCJ6T7B.lng
FEJQBGH5HMADJWM76TVYYVMEJLFV2VOV (1).lng
LPQVEKHU2P2B5DAJLQEQZIBOMQ6OZGZN (1).lng
LPQVEKHU2P2B5DAJLQEQZIBOMQ6OZGZN.lng
FEJQBGH5HMADJWM76TVYYVMEJLFV2VOV.lng
4XIYPPD6RHNFTL2RMMFYCPMBAH2RO6EY (1).lng
4XIYPPD6RHNFTL2RMMFYCPMBAH2RO6EY.lng
TYTNCJJOV2ZXJNLSNIQ5WTFS4OYPQHUE (1).lng
TYTNCJJOV2ZXJNLSNIQ5WTFS4OYPQHUE.lng
3IQERBMO33RL4GVSXQCO47LVJTDSGGB5 (1).lng
3IQERBMO33RL4GVSXQCO47LVJTDSGGB5.lng
GVR5NECRJLD6TYRMW3TUFV4PZUHCUMLM (1).lng
GVR5NECRJLD6TYRMW3TUFV4PZUHCUMLM.lng
T2KNFUSCZEZ3KZ5BLURBQ26IV7MKZAQX (1).lng
EUHJQDNOOVFZGAJKD2JMWM4JJ556YNPG (1).lng
EUHJQDNOOVFZGAJKD2JMWM4JJ556YNPG.lng
T2KNFUSCZEZ3KZ5BLURBQ26IV7MKZAQX.lng
ILQHSLSBULF2MKGDH3NUVVYTTKLXK76M (1).lng
7DUHK3DJATBAPHMBUBLQDVBZPTF7OSQL (1).lng
DGCQDZRY7OPRKAJ6W3EYAKPCTMTYUJN5 (1).lng
7DUHK3DJATBAPHMBUBLQDVBZPTF7OSQL.lng
DGCQDZRY7OPRKAJ6W3EYAKPCTMTYUJN5.lng
CDZXPL6KH5JWIGE5J52AWUTSGZE3ORZG (1).lng
ILQHSLSBULF2MKGDH3NUVVYTTKLXK76M.lng
CDZXPL6KH5JWIGE5J52AWUTSGZE3ORZG.lng
25YEZWJQMF6KNSEUG5NDTBCY3KZFDRCF (1).lng
25YEZWJQMF6KNSEUG5NDTBCY3KZFDRCF.lng
GQLQDF2BUBHXXSS7GDOVW6UV7VEUN2DU (1).lng
GQLQDF2BUBHXXSS7GDOVW6UV7VEUN2DU.lng
EK4D5USWXSPS6HL7WVPNATCH252APE47 (1).lng
TG2KMN6ZG7GPMNLCQ565SG2ZIAIRCLLC (1).lng
TG2KMN6ZG7GPMNLCQ565SG2ZIAIRCLLC.lng
EK4D5USWXSPS6HL7WVPNATCH252APE47.lng
3XTF5XNYRQZP7ZHQUW72W47JOIEA7PZ7 (1).lng
3XTF5XNYRQZP7ZHQUW72W47JOIEA7PZ7.lng
2BENIR3GKBORN65Z3WGBY2YTKTP75CHM (1).lng
2BENIR3GKBORN65Z3WGBY2YTKTP75CHM.lng
FASHZSEWG7FAYZ2FPLAVBFZSYXGGVAT2 (1).lng
6JYAPIBOZAX22V7UAV4N52TQBOV23XUY (1).lng
6JYAPIBOZAX22V7UAV4N52TQBOV23XUY.lng
FASHZSEWG7FAYZ2FPLAVBFZSYXGGVAT2.lng
HRXE7FPGFWFTLBIGGDFRONRUAWFUASLM (1).lng
WLGDHYNWZRUPE25SEH4B6CDZXDT5Q64H (1).lng
HRXE7FPGFWFTLBIGGDFRONRUAWFUASLM.lng
WLGDHYNWZRUPE25SEH4B6CDZXDT5Q64H.lng
GNUPLTXL2WMCO5S3YRDO7BKVQEN5NRVV (1).lng
GNUPLTXL2WMCO5S3YRDO7BKVQEN5NRVV.lng
PL6ZLUT4MEJFPS7J4I5YVDRQQN6CH7I6 (1).lng
PL6ZLUT4MEJFPS7J4I5YVDRQQN6CH7I6.lng
ITRY77OAKKNFMJCJN3HL7IPY6N7C575A (1).lng
K7XDMTHYCAVWVEPBWYRQCZGOUQ23VSL2 (1).lng
ITRY77OAKKNFMJCJN3HL7IPY6N7C575A.lng
K7XDMTHYCAVWVEPBWYRQCZGOUQ23VSL2.lng
DPY3AFLQZJXAWKFZE2XE7Y5CW35V4DVG (1).lng
4VY7A6CFF6RCDQGDCCREXKT2AFDTEP2I (1).lng
4VY7A6CFF6RCDQGDCCREXKT2AFDTEP2I.lng
DPY3AFLQZJXAWKFZE2XE7Y5CW35V4DVG.lng
C2VZVRL4TKBQG4644TOSYADIMY3RQPMG (1).lng
C2VZVRL4TKBQG4644TOSYADIMY3RQPMG.lng
EB3KBYZFV4BXSFKLMESEVHTRX4VEM6K2 (1).lng
EB3KBYZFV4BXSFKLMESEVHTRX4VEM6K2.lng
L6I2MALV6J5JNFS3L4NW2HQTYEZTXZTQ (1).lng
7LTCSGRMOGOD3SFVWKOF457ZNEASEG6P (1).lng
L6I2MALV6J5JNFS3L4NW2HQTYEZTXZTQ.lng
7LTCSGRMOGOD3SFVWKOF457ZNEASEG6P.lng
YUV5PXQGQ2WIQOKES6SL56COKJPVHQ3E (1).lng
CYPN27L4XMKXREPGLMUSHXY6FYLQK7F4 (1).lng
CYPN27L4XMKXREPGLMUSHXY6FYLQK7F4.lng
YUV5PXQGQ2WIQOKES6SL56COKJPVHQ3E.lng
22SYPAI4QXQMJQSNLN76JKXRTLYDBP7S (1).lng
22SYPAI4QXQMJQSNLN76JKXRTLYDBP7S.lng
BALHG3JD2AAKBYEHTVAUFB3KQ23GLZNE (1).lng
BALHG3JD2AAKBYEHTVAUFB3KQ23GLZNE.lng
ODG234XVIRZAI4QQRFAD36ELWPTBC5AD (1).lng
ODG234XVIRZAI4QQRFAD36ELWPTBC5AD.lng
L5ODGTZPVM2BY4XY2OHELZKCHVMEPAAI (1).lng
L5ODGTZPVM2BY4XY2OHELZKCHVMEPAAI.lng
DGQSMQA5CX7JBBJLUOJU2ZILPXATVIT7 (1).lng
DGQSMQA5CX7JBBJLUOJU2ZILPXATVIT7.lng
SHA25DLG6JOZI4O5B24KESEDZRAD65VZ (1).lng
SHA25DLG6JOZI4O5B24KESEDZRAD65VZ.lng
SGAJAB44UPWRBAMNCKXI7JCMUF2I2PRC (1).lng
J4UL7GZJMWW43CPFK7O4OFNNHHXKE3NL (1).lng
SGAJAB44UPWRBAMNCKXI7JCMUF2I2PRC.lng
J4UL7GZJMWW43CPFK7O4OFNNHHXKE3NL.lng
PZB7SZUJT5TQ6OPGOY64TWABMJTD5JOX (1).lng
PZB7SZUJT5TQ6OPGOY64TWABMJTD5JOX.lng
4WA3ZQ7KDWADZZZPJKA7OW54FME6734R (1).lng
4WA3ZQ7KDWADZZZPJKA7OW54FME6734R.lng
BDYYWK6YZJNMOI256IRH4X2CA5ZEM4FG (1).lng
2UJCIVA7TRF4JB42EZZ5JQIKQNJRY5Z3 (1).lng
BDYYWK6YZJNMOI256IRH4X2CA5ZEM4FG.lng
2UJCIVA7TRF4JB42EZZ5JQIKQNJRY5Z3.lng
LKINPWE7PAAXZYXA7T3JMW2YE35UKSC4 (1).lng
HCXKGW2LT7IMV75RDV4AQ2ZYCAD36ID2 (1).lng
LKINPWE7PAAXZYXA7T3JMW2YE35UKSC4.lng
HCXKGW2LT7IMV75RDV4AQ2ZYCAD36ID2.lng
TKW7K5YUWZXKV4EG7Y7DTDPGA2TGYRIS (1).lng
TKW7K5YUWZXKV4EG7Y7DTDPGA2TGYRIS.lng
VSTLZ3HEBGGAXTXG5OO2NTXVBQ7CGTZM (1).lng
VSTLZ3HEBGGAXTXG5OO2NTXVBQ7CGTZM.lng
IDW4CEHASPD5IKVVCYO7RR4MMLQ7DYNA (1).lng
3WRLMTQ36N4ZPAKVV2FJAKKTN2IHUWEW (1).lng
IDW4CEHASPD5IKVVCYO7RR4MMLQ7DYNA.lng
3WRLMTQ36N4ZPAKVV2FJAKKTN2IHUWEW.lng
XMX4CQLGHAQ5XMEBEHDLJYJADSIYKTO2 (1).lng
XMX4CQLGHAQ5XMEBEHDLJYJADSIYKTO2.lng
UYPO26A3OOEQ4E3N4XLNCMX4A3ZJQT5W (1).lng
UYPO26A3OOEQ4E3N4XLNCMX4A3ZJQT5W.lng
G3SD4RN6OZU2B7FYYIR35M6S6X4AOSVV (1).lng
AVIJDQGNCXHAC67HS2V42YBJYO6JFKLH (1).lng
G3SD4RN6OZU2B7FYYIR35M6S6X4AOSVV.lng
AVIJDQGNCXHAC67HS2V42YBJYO6JFKLH.lng
GYLOITFCEKBVOOWHP7ULSF5JLUR35EEB (1).lng
GYLOITFCEKBVOOWHP7ULSF5JLUR35EEB.lng
MLQSSXQFDTJYCJIABZCRLRZM2RUYCQI5 (1).lng
MLQSSXQFDTJYCJIABZCRLRZM2RUYCQI5.lng
FCCSANRH73ZAD5I4G2UPJHY73ZOG55YG (1).lng
3GYY3QMBPIEK3KTK6PC46KGMCEBNVOTS (1).lng
FCCSANRH73ZAD5I4G2UPJHY73ZOG55YG.lng
3GYY3QMBPIEK3KTK6PC46KGMCEBNVOTS.lng
HNBKMD7A7TG4CZWFJ7VFCJD6OCL4RAGK (1).lng
VJ4SHT2UU3A7ODTD776ONQE4Z5GXXV7M (1).lng
HNBKMD7A7TG4CZWFJ7VFCJD6OCL4RAGK.lng
VJ4SHT2UU3A7ODTD776ONQE4Z5GXXV7M.lng
WEMQ3SVVRDD4TNYO2YCKCQVMRIBEJRR2 (1).lng
KKKX46G5R3LOOHQXEFJIVEZURZ345A4W (1).lng
KKKX46G5R3LOOHQXEFJIVEZURZ345A4W.lng
WEMQ3SVVRDD4TNYO2YCKCQVMRIBEJRR2.lng
TU5KLX2LNCZN2UMSQ2SD2IPZGMVKHZRI (1).lng
QJCHY65YCB63DY547KNMHUWCK37SVLIY (1).lng
TU5KLX2LNCZN2UMSQ2SD2IPZGMVKHZRI.lng
QJCHY65YCB63DY547KNMHUWCK37SVLIY.lng
WVSID4CSRVH2NZZV2GTZUL6OUUQ7ZCT4 (1).lng
FCOAWPVMKWM2JV2AMJAKWZUAVT3ON5A6 (1).lng
FCOAWPVMKWM2JV2AMJAKWZUAVT3ON5A6.lng
WVSID4CSRVH2NZZV2GTZUL6OUUQ7ZCT4.lng
VONGRUWFL3QJ6OBLD6I5BNLAONMIM7C6 (1).lng
BGR4E3CKYEMDH5IMNS6SC6BDX4JRDK26 (1).lng
VONGRUWFL3QJ6OBLD6I5BNLAONMIM7C6.lng
BGR4E3CKYEMDH5IMNS6SC6BDX4JRDK26.lng
GSDPAGI53RE4FFENW6ALUAF6IBJ7WWVZ (1).lng
GSDPAGI53RE4FFENW6ALUAF6IBJ7WWVZ.lng
KLBEV3ATBWQQALCD65T553WDOXX32BKG (1).lng
KLBEV3ATBWQQALCD65T553WDOXX32BKG.lng
JD2ZRLPRQSQOE23WZVPTJFYO2N6LUBQX (1).lng
JBB2ID6SG3KKYQLPRJYYWYQ4T43A4N5B (1).lng
JBB2ID6SG3KKYQLPRJYYWYQ4T43A4N5B.lng
JD2ZRLPRQSQOE23WZVPTJFYO2N6LUBQX.lng
7ZKZ36GC3HZEEL6WLT547G3QOGLL2DIM (1).lng
O22CL3D75BLN2OLEC26LU2G5SDCKA66Y (1).lng
7ZKZ36GC3HZEEL6WLT547G3QOGLL2DIM.lng
O22CL3D75BLN2OLEC26LU2G5SDCKA66Y.lng
UESPHKQVQBWCB6OFQCQID2SBBQF5PMVR (1).lng
BAXEQ66SULFHK5HMTPYSFTAMZZ7HUHAL (1).lng
UESPHKQVQBWCB6OFQCQID2SBBQF5PMVR.lng
BAXEQ66SULFHK5HMTPYSFTAMZZ7HUHAL.lng
USGTH7RE7YEWHIKOJORNBN3GBR3EZVPY (1).lng
VZETUAHXSAFLW7G53I6AJASJXU2JQNPI (1).lng
VZETUAHXSAFLW7G53I6AJASJXU2JQNPI.lng
USGTH7RE7YEWHIKOJORNBN3GBR3EZVPY.lng
EJWDW3QIYYLS7IKSRBW7PKTZPBKCELJP (1).lng
IS7JRWB6Z46LV5I2HUMRP673ZO57PST7 (1).lng
IS7JRWB6Z46LV5I2HUMRP673ZO57PST7.lng
EJWDW3QIYYLS7IKSRBW7PKTZPBKCELJP.lng
2VYOIHIVHRBE3YZ4SEYMLSDTZAGG6ZQ2 (1).lng
L4VT5I26Z55SX3JLQU2FKI3C4YGMSA5G (1).lng
L4VT5I26Z55SX3JLQU2FKI3C4YGMSA5G.lng
2VYOIHIVHRBE3YZ4SEYMLSDTZAGG6ZQ2.lng
KGCBOWZVCHIGC4I7QEFC2HZTEUJIRMW6 (1).lng
3YRY7U52U4ZY224U46RV2FIGBVQFCTDR (1).lng
KGCBOWZVCHIGC4I7QEFC2HZTEUJIRMW6.lng
3YRY7U52U4ZY224U46RV2FIGBVQFCTDR.lng
H3SACYCJM4XM3NZRVZOACWD5PGQXCZVO (1).lng
56PL7GNLZG2S4QD7UXJMEM7NR5E7FNVM (1).lng
H3SACYCJM4XM3NZRVZOACWD5PGQXCZVO.lng
56PL7GNLZG2S4QD7UXJMEM7NR5E7FNVM.lng
7ZF2J67YCACM6KOCUDYDFSKUC45JK7KQ (1).lng
7ZF2J67YCACM6KOCUDYDFSKUC45JK7KQ.lng
4XSUKI4BDHLPTGCSWXQ5OCAC6INNXMY6 (1).lng
4XSUKI4BDHLPTGCSWXQ5OCAC6INNXMY6.lng
PMPMUXPUODT2M6UF3XAWECU7KPFPXFCP (1).lng
PMPMUXPUODT2M6UF3XAWECU7KPFPXFCP.lng
ELXAHXQKDTNY3TU37SUGZXMM4NJHMCHM (1).lng
ELXAHXQKDTNY3TU37SUGZXMM4NJHMCHM.lng
4PSI3TECC7IMABGHZJE3IKAZN7J7VVEF (1).lng
J2BWGFNR3EKV2HKFGEI7Y3BA6K4PA3RD (1).lng
J2BWGFNR3EKV2HKFGEI7Y3BA6K4PA3RD.lng
4PSI3TECC7IMABGHZJE3IKAZN7J7VVEF.lng
CWY37H3XZVSSZNPPHCGN5PIOIBZLXT5X (1).lng
HU3URFUV3FBZQ4IYUJT32QKW3UE3NOMW (1).lng
CWY37H3XZVSSZNPPHCGN5PIOIBZLXT5X.lng
HU3URFUV3FBZQ4IYUJT32QKW3UE3NOMW.lng
B6FE4LEVARYBADZVV4FY42GFCWR4ZHBL (1).lng
Y3OICM4CUVYWNT2OR32S3EQBDMS6XPME (1).lng
ZLTLXA3ULBN7UNQBYDM6QU3XNV74EB3A (1).lng
ZLTLXA3ULBN7UNQBYDM6QU3XNV74EB3A.lng
Y3OICM4CUVYWNT2OR32S3EQBDMS6XPME.lng
B6FE4LEVARYBADZVV4FY42GFCWR4ZHBL.lng
3A7UREBJ6THN73VEIZ5QPD5TVRDNL6I6 (1).lng
3A7UREBJ6THN73VEIZ5QPD5TVRDNL6I6.lng
GY43GEPONOQCRX5DM2CEVW32FB65X26S (1).lng
SJ32HVBI2OXDEA3K55JSE3NQVOQW4LYS (1).lng
SJ32HVBI2OXDEA3K55JSE3NQVOQW4LYS.lng
GY43GEPONOQCRX5DM2CEVW32FB65X26S.lng
XZAALK3DYJSZAZL3AS73MVVMGM7AXUNT (1).lng
N33I2EGZWTMZP2FJY55O7PODEKINZHOD (1).lng
XZAALK3DYJSZAZL3AS73MVVMGM7AXUNT.lng
N33I2EGZWTMZP2FJY55O7PODEKINZHOD.lng
LIOMPCZZUQFDIT26Q7UGAAPQ2UPT6J3D (1).lng
LIOMPCZZUQFDIT26Q7UGAAPQ2UPT6J3D.lng
H7K6CLKE33OUII45F34XL7PST2CDKA6F (1).lng
H7K6CLKE33OUII45F34XL7PST2CDKA6F.lng
YIAO7XSSV74BRKQMWMHII4KX4XCNBAMW (1).lng
ICX3UTP5DZ2G5HITHD2IXBJXOO4C5GDI (1).lng
ICX3UTP5DZ2G5HITHD2IXBJXOO4C5GDI.lng
YIAO7XSSV74BRKQMWMHII4KX4XCNBAMW.lng
IQUJVTY7N2XGDMRATVKFVWSMKWWETT4R (1).lng
IQUJVTY7N2XGDMRATVKFVWSMKWWETT4R.lng
IMJ77C2RDUS2OBHAWKFP2GDKFIKRPINX (1).lng
IMJ77C2RDUS2OBHAWKFP2GDKFIKRPINX.lng
CD3IZRZZEHHNIKQTGKIW2RPUEVZZV6KY (1).lng
JI45HFPX5JO7DU344HFTBD7MKMAYDZ3P (1).lng
JI45HFPX5JO7DU344HFTBD7MKMAYDZ3P.lng
CD3IZRZZEHHNIKQTGKIW2RPUEVZZV6KY.lng
B4BFLKSKZ4SDBTJXIQQA7JKAOVOSTB2X (1).lng
B4BFLKSKZ4SDBTJXIQQA7JKAOVOSTB2X.lng
7WL7IRD3XHTQ3XENG5MD7RU64Z2374MA (1).lng
7WL7IRD3XHTQ3XENG5MD7RU64Z2374MA.lng
WWJAYREF72YGJO2Q5ESBY3ZCA7VML7GE (1).lng
WWJAYREF72YGJO2Q5ESBY3ZCA7VML7GE.lng
6D753KMNVLM5FOPCBP6OYTPDYPV52L2Y (1).lng
6D753KMNVLM5FOPCBP6OYTPDYPV52L2Y.lng
YIHOTQCMHBRGLZ26RTZJTDFBS62KE6KX (1).lng
YIHOTQCMHBRGLZ26RTZJTDFBS62KE6KX.lng
GEB4MDGJSMAZECCCSCO2E6VMZVSKZ3RO (1).lng
GEB4MDGJSMAZECCCSCO2E6VMZVSKZ3RO.lng
F4QBS3FRDK33JEKX6VPQXUBHV452VPRZ (1).lng
56LHLWABRGPXAKWYFZLCJHJM4CBXGKLL (1).lng
56LHLWABRGPXAKWYFZLCJHJM4CBXGKLL.lng
F4QBS3FRDK33JEKX6VPQXUBHV452VPRZ.lng
5PYVB62TV4UCJZB6UUP372RTZ5QSWEPU (1).lng
CUISQEUAZE7TFBF5FQIBCYM75UYZMN7L (1).lng
CUISQEUAZE7TFBF5FQIBCYM75UYZMN7L.lng
5PYVB62TV4UCJZB6UUP372RTZ5QSWEPU.lng
KNBWD5XEI5T7DL37VVG4H7XKX4I3HL2D (1).lng
E5HP4F7KC3M6KJRMI5TFYQFMGRR2X4ZY (1).lng
E5HP4F7KC3M6KJRMI5TFYQFMGRR2X4ZY.lng
KNBWD5XEI5T7DL37VVG4H7XKX4I3HL2D.lng
THNWQP4SPKS2ZR5IKMQCWDHGISP4DC7M (1).lng
KHVWVKLABP47FBATCUI7AUFN2GROYEEY (1).lng
IKWVPBMJYVYDX4A6QVBMMSIWVYHS4UZB (1).lng
IKWVPBMJYVYDX4A6QVBMMSIWVYHS4UZB.lng
YASA2IZ7RBXCHJVNKGX5YIPYSD2NJSPF (1).lng
THNWQP4SPKS2ZR5IKMQCWDHGISP4DC7M.lng
YASA2IZ7RBXCHJVNKGX5YIPYSD2NJSPF.lng
KHVWVKLABP47FBATCUI7AUFN2GROYEEY.lng
CCVSL2JTE7YXELVGQQHZME2I6N6LONPY (1).lng
DFUHMC5RW3GD3LUZHQIP5IAAQQUZUZGX (1).lng
DFUHMC5RW3GD3LUZHQIP5IAAQQUZUZGX.lng
CCVSL2JTE7YXELVGQQHZME2I6N6LONPY.lng
SZQPRDF4VTLAH56QE3JCKY7HGVAYG7A6 (1).lng
WFZQ5VG3KCTHGLWRRJQHAE4XCNAEFDZS (1).lng
SZQPRDF4VTLAH56QE3JCKY7HGVAYG7A6.lng
WFZQ5VG3KCTHGLWRRJQHAE4XCNAEFDZS.lng
US7IRU34PL67GCKBTUB74W4CDQT3Z7HZ (1).lng
US7IRU34PL67GCKBTUB74W4CDQT3Z7HZ.lng
4YL4U3GVUMMO32II4RW66O24NUQ2KEQT (1).lng
4YL4U3GVUMMO32II4RW66O24NUQ2KEQT.lng
MW4SVA7D4SOSXM2LMZR6QS27G2OMWAOK (1).lng
MW4SVA7D4SOSXM2LMZR6QS27G2OMWAOK.lng
UMRTTH6FMVQ6367RIW6Y4K7EBMGJ3OHX (1).lng
UMRTTH6FMVQ6367RIW6Y4K7EBMGJ3OHX.lng
5NBAQ7V6KDQ654YIPIFQITS5R27R6P53 (1).lng
D536Z7FEFFBW22H6HOXONYBOXC63LTWT (1).lng
5NBAQ7V6KDQ654YIPIFQITS5R27R6P53.lng
D536Z7FEFFBW22H6HOXONYBOXC63LTWT.lng
HEB5ZWV3MFY3R5ONZGEQICD7AKPHV3V3 (1).lng
ZEWHFQM6S4BV6CRUK5K27FASIKWSKOVF (1).lng
ZEWHFQM6S4BV6CRUK5K27FASIKWSKOVF.lng
HEB5ZWV3MFY3R5ONZGEQICD7AKPHV3V3.lng
GLU47G5TNE3P3VTCTDTP4FOJTA3DYJMF (1).lng
5ZLURKU45HCWIVWVDTI6XSMK24OSNSYC (1).lng
5ZLURKU45HCWIVWVDTI6XSMK24OSNSYC.lng
GLU47G5TNE3P3VTCTDTP4FOJTA3DYJMF.lng
WG6NPADRJLI4TA4APJJWD7DMXNH2VJ4J (1).lng
WF5J6WY7V2QGB2ZGIO7XLFOMS7QIQPFV (1).lng
WF5J6WY7V2QGB2ZGIO7XLFOMS7QIQPFV.lng
WG6NPADRJLI4TA4APJJWD7DMXNH2VJ4J.lng
RGWR2CV2UU3V7BDYEVUW7OHZDDOSCXRP (1).lng
RGWR2CV2UU3V7BDYEVUW7OHZDDOSCXRP.lng
2H5A3JXU3XE5ABMDFSG3SYEKN6ABWB7K (1).lng
2H5A3JXU3XE5ABMDFSG3SYEKN6ABWB7K.lng
WV4LM2J7AI77ZB3YYM7HOTDWWQHSKEJK (1).lng
TJDMDOJ65SKETIOXJ23SRBDVTEBSLSUS (1).lng
WV4LM2J7AI77ZB3YYM7HOTDWWQHSKEJK.lng
TJDMDOJ65SKETIOXJ23SRBDVTEBSLSUS.lng
PIPGWW47JOPK734PBUJMIA4PDGJ5NTQB (1).lng
656BALCGIGPH6A7BYAMTAAJIBITKSZRU (1).lng
PIPGWW47JOPK734PBUJMIA4PDGJ5NTQB.lng
656BALCGIGPH6A7BYAMTAAJIBITKSZRU.lng
VS722265AI4SBISNIRYAKZ4KIV6X4Q75 (1).lng
VS722265AI4SBISNIRYAKZ4KIV6X4Q75.lng
ZNZZPCT5VYHAOUP2KRK6FWVNAZZZEUDU (1).lng
ZNZZPCT5VYHAOUP2KRK6FWVNAZZZEUDU.lng
OCMG33S3VRXWZ6C7TYTHU63H3KWDGXMT (1).lng
GZQM25YEM4MJ5QJVSONFJ6ZEZEEVOUKP (1).lng
OCMG33S3VRXWZ6C7TYTHU63H3KWDGXMT.lng
GZQM25YEM4MJ5QJVSONFJ6ZEZEEVOUKP.lng
JL4KMM2564LLIQ6RA36SZBKEOEJF5RHX (1).lng
GT7OPEFRBA7WG7QGT3AYDX2JP474DPYB (1).lng
GT7OPEFRBA7WG7QGT3AYDX2JP474DPYB.lng
JL4KMM2564LLIQ6RA36SZBKEOEJF5RHX.lng
MMWTTKQRUTUEI72XYKOBQUYP4YHSQ45F (1).lng
66OMB3L6LACDLA4UF4TLRCJ7LQDEDFLI (1).lng
66OMB3L6LACDLA4UF4TLRCJ7LQDEDFLI.lng
MMWTTKQRUTUEI72XYKOBQUYP4YHSQ45F.lng
LWDCQQM32ZZXO4ENJWNIE2VWRRFXM6BV (1).lng
LWDCQQM32ZZXO4ENJWNIE2VWRRFXM6BV.lng
LHVY6OLDSFOTAT57JYJNOB7PVLYMF5ZD (1).lng
LHVY6OLDSFOTAT57JYJNOB7PVLYMF5ZD.lng
6SXRW2UWN4NHWJ3DQIJNR33HUOY6B5VQ (1).lng
44FUBZDTQJFKU634IPEGJ5KDTWVMYSKQ (1).lng
6SXRW2UWN4NHWJ3DQIJNR33HUOY6B5VQ.lng
44FUBZDTQJFKU634IPEGJ5KDTWVMYSKQ.lng
5D4MU2USGU6PAHZA6ALMUENJ4T64OPC7 (1).lng
2SJPFXNF4AJG6IGA4I22IJL5TQMXNZDD (1).lng
2SJPFXNF4AJG6IGA4I22IJL5TQMXNZDD.lng
5D4MU2USGU6PAHZA6ALMUENJ4T64OPC7.lng
WDL3S4ZQK7ZKUMZ6DOY4F4G6UNDUG3PQ (1).lng
WDL3S4ZQK7ZKUMZ6DOY4F4G6UNDUG3PQ.lng
JE6A3TCTQHZ5PK2AUAS5DZRZDTJ5AFV6 (1).lng
JE6A3TCTQHZ5PK2AUAS5DZRZDTJ5AFV6.lng
ONLTKPBGPDK3XVMVG4FVLKWD7PUKE3YS (1).lng
QFWKFUYTQ4GY5MWOLZX65OMUZSBQLXX7 (1).lng
QFWKFUYTQ4GY5MWOLZX65OMUZSBQLXX7.lng
ONLTKPBGPDK3XVMVG4FVLKWD7PUKE3YS.lng
GF4FYJS2OT4RZ2M3AIVAKLQGRMNLVAWI (1).lng
EFMIP4HTKQW5CA6TW56IE47SE2XR33F4 (1).lng
GF4FYJS2OT4RZ2M3AIVAKLQGRMNLVAWI.lng
EFMIP4HTKQW5CA6TW56IE47SE2XR33F4.lng
HCUWHHTO6U7WTNU3RFF3PNWF2T3PKUCT (1).lng
5JZ62DPGNRSJDETP5BIEFV6I2CEEA4HH (1).lng
5JZ62DPGNRSJDETP5BIEFV6I2CEEA4HH.lng
C375O5J52BPLNBHSRWUKF7IZ6EQJJM76 (1).lng
HCUWHHTO6U7WTNU3RFF3PNWF2T3PKUCT.lng
HFF3QVFJ4OQNQEX2ZM3XRY35FGSVQXWD (1).lng
C375O5J52BPLNBHSRWUKF7IZ6EQJJM76.lng
HFF3QVFJ4OQNQEX2ZM3XRY35FGSVQXWD.lng
XKSEZ4ZNOGEN6ZBVXFP36C2G5MDE4AC7 (1).lng
XKSEZ4ZNOGEN6ZBVXFP36C2G5MDE4AC7.lng
NTNQBGIOUETMMSXIA2YQNTZCEN55WBOB (1).lng
NTNQBGIOUETMMSXIA2YQNTZCEN55WBOB.lng
HQOGNRKTAWPCUNS3KPGRNR2OPKJB4WC3 (1).lng
ERJBWGIDHKB2EL55JCURQZIK2W6YB7WO (1).lng
ERJBWGIDHKB2EL55JCURQZIK2W6YB7WO.lng
HQOGNRKTAWPCUNS3KPGRNR2OPKJB4WC3.lng
XYKYJU46Q64YXBE32OFJXLXZYQZEAM2B (1).lng
C4CYPSOTXHKFCCO3VVXDREOTEWAALZ53 (1).lng
XYKYJU46Q64YXBE32OFJXLXZYQZEAM2B.lng
C4CYPSOTXHKFCCO3VVXDREOTEWAALZ53.lng
IZRUPLMR2UPXCGQI3Z4LEKU2RAV5VUSG (1).lng
CB44KFLGVUY7FMEUSRRRPCO7ZPURP44K (1).lng
IZRUPLMR2UPXCGQI3Z4LEKU2RAV5VUSG.lng
CB44KFLGVUY7FMEUSRRRPCO7ZPURP44K.lng
TPZPJUM7BR76VJR4LOPS3IPGZYOV5EWJ (1).lng
TPZPJUM7BR76VJR4LOPS3IPGZYOV5EWJ.lng
B33E4VCDQPZOIVMMCM5376MWBGY22YY3 (1).lng
B33E4VCDQPZOIVMMCM5376MWBGY22YY3.lng
ARY5FG5IEGFXTLLNL5EER43GU6RLEO2D (1).lng
6IKHDL76HXV63TEMOZHO7D6RUCZ3HHOU (1).lng
ARY5FG5IEGFXTLLNL5EER43GU6RLEO2D.lng
6IKHDL76HXV63TEMOZHO7D6RUCZ3HHOU.lng
MGDQLQROJXACHRMQALM36HN3FO4SQSIK (1).lng
GPN3BA3VSBF4ALB44OTIKAPS62J2MLKF (1).lng
GPN3BA3VSBF4ALB44OTIKAPS62J2MLKF.lng
MGDQLQROJXACHRMQALM36HN3FO4SQSIK.lng
KTOK7H6MIBMGZYQVQ3K4XZSC5S5TXYF7 (1).lng
UI6IYKJ2NQT3T5QPRBXCFM5DBLMPSQBW (1).lng
UI6IYKJ2NQT3T5QPRBXCFM5DBLMPSQBW.lng
KTOK7H6MIBMGZYQVQ3K4XZSC5S5TXYF7.lng
6LV22IY4VFT3BAW3TZBTKD3KNYSXYWVC (1).lng
OOUAC4H3RNIER6OUGO6UIKNNH7OSRTJO (1).lng
6LV22IY4VFT3BAW3TZBTKD3KNYSXYWVC.lng
OOUAC4H3RNIER6OUGO6UIKNNH7OSRTJO.lng
47WHXWYCHW4VYIQSBA66LHQ75XGACEZB (1).lng
DE72UGMI2WT646MSLO3Y63ARYKLIEFEA (1).lng
47WHXWYCHW4VYIQSBA66LHQ75XGACEZB.lng
DE72UGMI2WT646MSLO3Y63ARYKLIEFEA.lng
L7OMHGCQMRWX4CGD3JLQEONAF3JZZ44T (1).lng
L7OMHGCQMRWX4CGD3JLQEONAF3JZZ44T.lng
WENM7VXIVRLM7WVDR4UNSIWSQEIQPRQ3 (1).lng
WENM7VXIVRLM7WVDR4UNSIWSQEIQPRQ3.lng
HT6KGGQYC2MAUINTUQZS2MMR2FHMRXGH (1).lng
QD6Y25OLPHENLHEATJSF65D7EIJMN2VK (1).lng
QD6Y25OLPHENLHEATJSF65D7EIJMN2VK.lng
HT6KGGQYC2MAUINTUQZS2MMR2FHMRXGH.lng
M2JQISN37TOKAK4ENLICYQOZXBIXY4NX (1).lng
L4UD6UWAOJ7TALWP55BXZFE6WETW4MSB (1).lng
M2JQISN37TOKAK4ENLICYQOZXBIXY4NX.lng
L4UD6UWAOJ7TALWP55BXZFE6WETW4MSB.lng
A7TSXN33ORMINEPRBZV4RJLWU3YGOZQS (1).lng
YXS7ENPG3BFLCBMCQIAER3UK3AAM7YGJ (1).lng
A7TSXN33ORMINEPRBZV4RJLWU3YGOZQS.lng
YXS7ENPG3BFLCBMCQIAER3UK3AAM7YGJ.lng
PPKSHJEJZ2XN4AQZXFKCTDXKG25WOXW4 (1).lng
DTO6HNMJHRFEMLCTIC2VTC7NL6LL23WQ (1).lng
DTO6HNMJHRFEMLCTIC2VTC7NL6LL23WQ.lng
PPKSHJEJZ2XN4AQZXFKCTDXKG25WOXW4.lng
3S47CMTHJ2OJEJ7VYJTT3J3KDXWF2WN7 (1).lng
FBQU3TNJLTGQGIHV74S2DFBE5DK475JJ (1).lng
FBQU3TNJLTGQGIHV74S2DFBE5DK475JJ.lng
3S47CMTHJ2OJEJ7VYJTT3J3KDXWF2WN7.lng
P6WCRZTCBT5PMUPW2RBOM4E75THOD5TI (1).lng
TOZSZJUTZUGBG5NJVYJCAVTTC47DURBY (1).lng
TOZSZJUTZUGBG5NJVYJCAVTTC47DURBY.lng
P6WCRZTCBT5PMUPW2RBOM4E75THOD5TI.lng
FNUB3X3M6ZBJ4EFD4GVZJZWIGEM644KJ (1).lng
DN4TA6WE2WOAOA4P4ROSYOR5DM6VBPGA (1).lng
DN4TA6WE2WOAOA4P4ROSYOR5DM6VBPGA.lng
FNUB3X3M6ZBJ4EFD4GVZJZWIGEM644KJ.lng
JT4QTB5IUHPNQWS52PX55HVLVWUU44UA (1).lng
RQTFFN6UFBW7A4AWZ3QAQDAIT4LQGKPH (1).lng
RQTFFN6UFBW7A4AWZ3QAQDAIT4LQGKPH.lng
JT4QTB5IUHPNQWS52PX55HVLVWUU44UA.lng
AN44TPHUMKYD3ZIPO7IDKK7ZHK7QWAIC (1).lng
U4U6D3UIWL436JOCGOEEULYVGHOWPKDJ (1).lng
AN44TPHUMKYD3ZIPO7IDKK7ZHK7QWAIC.lng
U4U6D3UIWL436JOCGOEEULYVGHOWPKDJ.lng
UTIRMA7ZGJMKKMFYUUSDPPCF2B2T6MJA (1).lng
7XMBIVHNNH6OEIE5JTMMOHXNN7SL7B7R (1).lng
UTIRMA7ZGJMKKMFYUUSDPPCF2B2T6MJA.lng
7XMBIVHNNH6OEIE5JTMMOHXNN7SL7B7R.lng
43HNOYECJOELOSYPXT5VJN7SYKS6OEW4 (1).lng
UNCHF5W7TY7KRJ3NMZKGXSKUTYGS6ESK (1).lng
UNCHF5W7TY7KRJ3NMZKGXSKUTYGS6ESK.lng
43HNOYECJOELOSYPXT5VJN7SYKS6OEW4.lng
SFNGWVYRVDI233TLXPJGJJDFORG2VQGM (1).lng
SFNGWVYRVDI233TLXPJGJJDFORG2VQGM.lng
DSS7SKCZ5VCUN4M635QVSJMQJ4S5VI43 (1).lng
DSS7SKCZ5VCUN4M635QVSJMQJ4S5VI43.lng
KXYZQKOOWLNANMYS6TDRPUJAQVAKPQ4T (1).lng
OLPWCYCBYWSKYM6Y7GXSYQOJJ3ESCA62 (1).lng
OLPWCYCBYWSKYM6Y7GXSYQOJJ3ESCA62.lng
KXYZQKOOWLNANMYS6TDRPUJAQVAKPQ4T.lng
N7FDXJZZFAJXONK5H6GGRHDA2NX63J2R (1).lng
N7FDXJZZFAJXONK5H6GGRHDA2NX63J2R.lng
4QYCIKIA66PLQBBDUQX2RFG4Y6STTTAL (1).lng
4QYCIKIA66PLQBBDUQX2RFG4Y6STTTAL.lng
JA6QBDX4PLSAU4ZNGI6LHGDD3YXMJMBB (1).lng
VP7RZATH57WFQWORWOMDIQULZ6LRKBBI (1).lng
JA6QBDX4PLSAU4ZNGI6LHGDD3YXMJMBB.lng
VP7RZATH57WFQWORWOMDIQULZ6LRKBBI.lng
YIH37A4O5DTX6LGMJGKU3V75O7WYEDVU (1).lng
CSKAN32KTOPC6EWADXC4BKTB3XWDHGJU (1).lng
YIH37A4O5DTX6LGMJGKU3V75O7WYEDVU.lng
CSKAN32KTOPC6EWADXC4BKTB3XWDHGJU.lng
A6OCHOOTGFNTSNZUPJ2T327GDXY2VHXT (1).lng
DLDFFA3PFB6MPDEFXVDPC25A4OYXC3TE (1).lng
DLDFFA3PFB6MPDEFXVDPC25A4OYXC3TE.lng
A6OCHOOTGFNTSNZUPJ2T327GDXY2VHXT.lng
HMSDPAIUVVWJWWERSXAFSLFF3QMTCSHU (1).lng
IF5XMK3ZIH6KBF6UYCY3G3Z5KUAV4VWA (1).lng
IF5XMK3ZIH6KBF6UYCY3G3Z5KUAV4VWA.lng
HMSDPAIUVVWJWWERSXAFSLFF3QMTCSHU.lng
3OX7RPBNQVPJR3V74KSO6BMBNVNF6PTK (1).lng
MJJ4KYJLRR5HG7UHAK62QTNI5JUSBXN2 (1).lng
MJJ4KYJLRR5HG7UHAK62QTNI5JUSBXN2.lng
3OX7RPBNQVPJR3V74KSO6BMBNVNF6PTK.lng
E7PY25JFLYDCA6KA6Z7EWNRSO3G55T6H (1).lng
QPSWDW24GBWLKMM7T4KW6JAPZTE3JTFX (1).lng
E7PY25JFLYDCA6KA6Z7EWNRSO3G55T6H.lng
QPSWDW24GBWLKMM7T4KW6JAPZTE3JTFX.lng
HSMTPH4X56T5OE7SNVOTAOSFJMLO3SMJ (1).lng
HSMTPH4X56T5OE7SNVOTAOSFJMLO3SMJ.lng
7JTZ5YJDYYOCWUUPPVU2ONQQV6O5SVIX (1).lng
7JTZ5YJDYYOCWUUPPVU2ONQQV6O5SVIX.lng
BQQGCDAQW4AKFQB2N3YW3MBQA7HRF3VW (1).lng
74WPUXOSFP2NRY5O5WPUEDEAV2AGPGSC (1).lng
74WPUXOSFP2NRY5O5WPUEDEAV2AGPGSC.lng
BQQGCDAQW4AKFQB2N3YW3MBQA7HRF3VW.lng
S4ETRFVXZLPCBWIO6SMKMZLAASVC2VVW (1).lng
S4ETRFVXZLPCBWIO6SMKMZLAASVC2VVW.lng
5SFHJUDKAYMG5WJWQI2C6W2QLBKABXMR (1).lng
5SFHJUDKAYMG5WJWQI2C6W2QLBKABXMR.lng
L6A77KR3BUKE4UVT5N4VIC6R6ZGBUXXW (1).lng
CDMEIVMZZXMFAKTXC4UIVSG2ET3P5YGL (1).lng
L6A77KR3BUKE4UVT5N4VIC6R6ZGBUXXW.lng
CDMEIVMZZXMFAKTXC4UIVSG2ET3P5YGL.lng
E5QA3P77KVGSDZEVXJQEHT4BWZVQREF5 (1).lng
ZNCQLACPYJ4AEZ2RXWXUG7QZLNC46C74 (1).lng
E5QA3P77KVGSDZEVXJQEHT4BWZVQREF5.lng
ZNCQLACPYJ4AEZ2RXWXUG7QZLNC46C74.lng
J5OXJOV3CMPNDTK53Z66ZX5GFHEAWJGD (1).lng
KVSPJN2UQS2PMQEYRT5HT6FVUU5USSPH (1).lng
KVSPJN2UQS2PMQEYRT5HT6FVUU5USSPH.lng
J5OXJOV3CMPNDTK53Z66ZX5GFHEAWJGD.lng
Y4I32AOWWLO3VW4C727HKS2T7VLX3XNO (1).lng
ABZV32OC5O6SKNHKHVJY5KCWKQJYCXVU (1).lng
ABZV32OC5O6SKNHKHVJY5KCWKQJYCXVU.lng
Y4I32AOWWLO3VW4C727HKS2T7VLX3XNO.lng
BTA4MM2MOUKBQ4AAKTDHRM3WE7GTNM5U (1).lng
BTA4MM2MOUKBQ4AAKTDHRM3WE7GTNM5U.lng
KLKO45PJYCJLHZDMFRFTTTJKM3TDERMQ (1).lng
KLKO45PJYCJLHZDMFRFTTTJKM3TDERMQ.lng
LQVZ5UTNYVFUCMPCGACUMHV2QRFMGXAN (1).lng
RCRD7FUAMFL7AO6DA4KZQLJ7TZAZ7626 (1).lng
LQVZ5UTNYVFUCMPCGACUMHV2QRFMGXAN.lng
RCRD7FUAMFL7AO6DA4KZQLJ7TZAZ7626.lng
WNK4KOSKOVX3K5R4PWVQQIJ7YO3PYTZQ (1).lng
O64TP6WX7XK6SMFYDJWAZI5KXUIA3FUF (1).lng
WNK4KOSKOVX3K5R4PWVQQIJ7YO3PYTZQ.lng
O64TP6WX7XK6SMFYDJWAZI5KXUIA3FUF.lng
X6MP75OW4R6WVSQBF4ZFA7VSCUJEVEUC (1).lng
I452HUCS6QGOLCSFXASEE2CMS6BIJSQ3 (1).lng
X6MP75OW4R6WVSQBF4ZFA7VSCUJEVEUC.lng
I452HUCS6QGOLCSFXASEE2CMS6BIJSQ3.lng
AN5XJALI36AFFQ5QH2SC54G3WTMKOTZM (1).lng
46Q42OZH4ZA7T3XNC7O5PWF5T6RAYFOW (1).lng
AN5XJALI36AFFQ5QH2SC54G3WTMKOTZM.lng
46Q42OZH4ZA7T3XNC7O5PWF5T6RAYFOW.lng
SEI5YPV3ES6N4RQRRRZKN23C4K67LV5I (1).lng
SEI5YPV3ES6N4RQRRRZKN23C4K67LV5I.lng
JQYLYEZNH7WQ2I7IGGZEJAIGRZ2GOW5I (1).lng
JQYLYEZNH7WQ2I7IGGZEJAIGRZ2GOW5I.lng
2YV5FHL6SAADV7Q5ZURYJVSU3K3GZKDW (1).lng
2YV5FHL6SAADV7Q5ZURYJVSU3K3GZKDW.lng
YH3FKUAWIJWF3H5P4BUZW2N7F4IJFKWV (1).lng
YH3FKUAWIJWF3H5P4BUZW2N7F4IJFKWV.lng
QHMCTDOM4HFPKYBXPHB7UKJQ3H4GLUW3 (1).lng
QHMCTDOM4HFPKYBXPHB7UKJQ3H4GLUW3.lng
RWNMT44G3ULHSBDFRFRR6WDGUZ3T6Q5W (1).lng
RWNMT44G3ULHSBDFRFRR6WDGUZ3T6Q5W.lng
SMRM77KVUZPWB7RGEEHNJTLPKMYS6NVQ (1).lng
7LRODGFOQZSKVRFAL5AKCFZPVMYRLP6P (1).lng
SMRM77KVUZPWB7RGEEHNJTLPKMYS6NVQ.lng
7LRODGFOQZSKVRFAL5AKCFZPVMYRLP6P.lng
S7WOKIM43INVNXUFZYHQJ6FRARPABG2K (1).lng
5BAO6O7NITWO66IAFQSIOIYEEPUANA2L (1).lng
CCUZPBQWX2DQKNCIGNGNUTBL5RAT2LBV (1).lng
RFEXGLICKUFDRXDG3TNVZ6HFKWHZK723 (1).lng
CCUZPBQWX2DQKNCIGNGNUTBL5RAT2LBV.lng
5BAO6O7NITWO66IAFQSIOIYEEPUANA2L.lng
S7WOKIM43INVNXUFZYHQJ6FRARPABG2K.lng
RFEXGLICKUFDRXDG3TNVZ6HFKWHZK723.lng
PXMJ5TLUNYYXO6D65FWHZCYWDBJIR6J4 (1).lng
PXMJ5TLUNYYXO6D65FWHZCYWDBJIR6J4.lng
IP5PQNAZ2ICPLXTYJYSQHRE75H5MESIQ (1).lng
IP5PQNAZ2ICPLXTYJYSQHRE75H5MESIQ.lng
PJUGJZF55KVNIRQQCUKQQBIKUMVXBLOP (1).lng
ZC3UV6TMBN6NRWJ2S5UG4VXD6RFRKLOX (1).lng
PJUGJZF55KVNIRQQCUKQQBIKUMVXBLOP.lng
ZC3UV6TMBN6NRWJ2S5UG4VXD6RFRKLOX.lng
ZDGYFTWMYDCUIW73WLHTQTI5K2A7U4LY (1).lng
WTWZUVLRO76JQB3NTTVE2TBWYDLSDGUU (1).lng
WTWZUVLRO76JQB3NTTVE2TBWYDLSDGUU.lng
ZDGYFTWMYDCUIW73WLHTQTI5K2A7U4LY.lng
MBCVZ5JXPBW4HXEJE4MBR254OUUXKSQ3 (1).lng
MBCVZ5JXPBW4HXEJE4MBR254OUUXKSQ3.lng
FGPNTT442ZW76TE6KA33QVEY26EWKFLF (1).lng
FGPNTT442ZW76TE6KA33QVEY26EWKFLF.lng
G6B4ICFRCM4VPHEPUSMRFXX4UWVHNYFS (1).lng
G6B4ICFRCM4VPHEPUSMRFXX4UWVHNYFS.lng
WGOMYLHCWXMD26Y6GJFEPEZIPXTXLF4B (1).lng
WGOMYLHCWXMD26Y6GJFEPEZIPXTXLF4B.lng
F5BMGKKQHKAEHFDHOM7QWNTLSTHMNMBJ (1).lng
45VXLI7V2DLXO5UCSTFJZRSYT6X4X6QH (1).lng
F5BMGKKQHKAEHFDHOM7QWNTLSTHMNMBJ.lng
45VXLI7V2DLXO5UCSTFJZRSYT6X4X6QH.lng
GJZAWUZBF2SGLH5K5R4GTNJANEBIQYIH (1).lng
BJ7GHJB775IA3RNHGK6BUEFOVZBJN57S (1).lng
GJZAWUZBF2SGLH5K5R4GTNJANEBIQYIH.lng
BJ7GHJB775IA3RNHGK6BUEFOVZBJN57S.lng
G3UC2XGXXRTO7JWHUWYNPYNTPWQ62H5P (1).lng
G3UC2XGXXRTO7JWHUWYNPYNTPWQ62H5P.lng
2CSWNRAB56OCSZZ3OH45URWCVE3CXCGK (1).lng
2CSWNRAB56OCSZZ3OH45URWCVE3CXCGK.lng
XWYT2TCTWFIJGMWISCP24NGXRK42YBLB (1).lng
CBGRPTO2CPWYZUSYCL6VGZDEI6DBTVY4 (1).lng
XWYT2TCTWFIJGMWISCP24NGXRK42YBLB.lng
CBGRPTO2CPWYZUSYCL6VGZDEI6DBTVY4.lng
FJXOXDTFNJLEE4U7BJNEPCLCPK226S7S (1).lng
FJXOXDTFNJLEE4U7BJNEPCLCPK226S7S.lng
PFJJD5ODHWVAGPOTQC5MURQJDL7KZTK6 (1).lng
PFJJD5ODHWVAGPOTQC5MURQJDL7KZTK6.lng
KDRNY5IBV3Q37MU7M4CQJMT3W5LIAEQ5 (1).lng
HU3PBCCJGJGY4SADSJTUDGR4ICGZPNJS (1).lng
HU3PBCCJGJGY4SADSJTUDGR4ICGZPNJS.lng
KDRNY5IBV3Q37MU7M4CQJMT3W5LIAEQ5.lng
J6YJTHIMZJ7Z26L5FTYYFBLOEATRN33A (1).lng
J6YJTHIMZJ7Z26L5FTYYFBLOEATRN33A.lng
734NRJM6W5QT5AD4LMYDBT46MPOXGCFO (1).lng
734NRJM6W5QT5AD4LMYDBT46MPOXGCFO.lng
G32NVRMXAKQBA4IN6TNZCZUKHKOZOA3L (1).lng
DPPQFN6KMXWVGQ4SSO3UOMO6DN3UFFON (1).lng
DPPQFN6KMXWVGQ4SSO3UOMO6DN3UFFON.lng
G32NVRMXAKQBA4IN6TNZCZUKHKOZOA3L.lng
RJLZQKRFDEFG7CZAPN52ILBDTOSZKGTC (1).lng
CQ2447H7X5SQPKMSJRWKSDQVXDOHRNVE (1).lng
CQ2447H7X5SQPKMSJRWKSDQVXDOHRNVE.lng
RJLZQKRFDEFG7CZAPN52ILBDTOSZKGTC.lng
KUHE5RBLGJDGYQOQSRGPBQUF6HPF5SJH (1).lng
VUGESMZCXTSP64H2M3COUJO7ZT356ZU6 (1).lng
VUGESMZCXTSP64H2M3COUJO7ZT356ZU6.lng
KUHE5RBLGJDGYQOQSRGPBQUF6HPF5SJH.lng
Q2T7MXIF6GWAQVTM6AUMQPVFUZTFWBQG (1).lng
KFURHF23P5A54QR6MZH5WYKTAPRAUJZO (1).lng
Q2T7MXIF6GWAQVTM6AUMQPVFUZTFWBQG.lng
KFURHF23P5A54QR6MZH5WYKTAPRAUJZO.lng
TUGENM6G5R3A5YKBE7JSI4RPVWY3H4EP (1).lng
TAO6CNURUQD2CP7JR5HYMWZPECPXS4HF (1).lng
TUGENM6G5R3A5YKBE7JSI4RPVWY3H4EP.lng
TAO6CNURUQD2CP7JR5HYMWZPECPXS4HF.lng
ORQDV5TZREUMB3RTK6QBOYYI5WCUJ5PZ (1).lng
ORQDV5TZREUMB3RTK6QBOYYI5WCUJ5PZ.lng
Biz
April 20, 2020, 7:37am
10
UUV4TB2AVQEYRJBK5MTRDF3M6GEYCA46 (1).lng
UUV4TB2AVQEYRJBK5MTRDF3M6GEYCA46.lng
DQ42BYKKQMIHMGUDUDA4OFFIA4GM6SIE (1).lng
DQ42BYKKQMIHMGUDUDA4OFFIA4GM6SIE.lng
6RUHUR6HH7OQMJIQ2VZ5YL7KW7HQ6XMC (1).lng
6RUHUR6HH7OQMJIQ2VZ5YL7KW7HQ6XMC.lng
D46C2M3XRUXCRJC3S6VNFTWMNYCYZFCA (1).lng
7XFIVNH2XZAR7Z3NFKCXJIRI6NIOV2LQ (1).lng
7XFIVNH2XZAR7Z3NFKCXJIRI6NIOV2LQ.lng
D46C2M3XRUXCRJC3S6VNFTWMNYCYZFCA.lng
SQ3PFNDZAHN3B4Z7RAAAGAICMOUXITWX (1).lng
JHNUBVP5DRABL5IOJKLVTVGAHSKLGC3O (1).lng
SQ3PFNDZAHN3B4Z7RAAAGAICMOUXITWX.lng
JHNUBVP5DRABL5IOJKLVTVGAHSKLGC3O.lng
3EYKI3TMFCFF74UZTCFO2SL3QHNA2P3B (1).lng
237TUJDXESRDEHFEXOBJG3Z7YOSBYT4H (1).lng
3EYKI3TMFCFF74UZTCFO2SL3QHNA2P3B.lng
237TUJDXESRDEHFEXOBJG3Z7YOSBYT4H.lng
HLDA2CAFCKQWSEMUPIP643V3ZDZALAAT (1).lng
HLDA2CAFCKQWSEMUPIP643V3ZDZALAAT.lng
G63IP3LU32WHGXZUNYQWAO5LBDUGECNH (1).lng
G63IP3LU32WHGXZUNYQWAO5LBDUGECNH.lng
JVIGNHZJOV2VR3QY46YLE6Q5NQLTX7ES (1).lng
R5ZQ3JRQ3BTVPH5TXRAMNDBF4HUIXKMN (1).lng
R5ZQ3JRQ3BTVPH5TXRAMNDBF4HUIXKMN.lng
JVIGNHZJOV2VR3QY46YLE6Q5NQLTX7ES.lng
UQQK66BYCYNTKCUIFJVJIA2RPYVKEBWE (1).lng
UQQK66BYCYNTKCUIFJVJIA2RPYVKEBWE.lng
5OVGOTEAFCVRIEHAWERWYVRGLO6ECRNH (1).lng
5OVGOTEAFCVRIEHAWERWYVRGLO6ECRNH.lng
VEQJV3DQSOCKRTLOIQF7OSRLYW7BLWNR (1).lng
R4KIZAUOMHXVZHPOUYHNSUMGV34RYHBF (1).lng
VEQJV3DQSOCKRTLOIQF7OSRLYW7BLWNR.lng
R4KIZAUOMHXVZHPOUYHNSUMGV34RYHBF.lng
S566QSRKYUSFKUHWDUAZEZOV2CNZJAQI (1).lng
S566QSRKYUSFKUHWDUAZEZOV2CNZJAQI.lng
QOLS4KPFNXCQ767CDSZENV7ZWWTFJD5Y (1).lng
QOLS4KPFNXCQ767CDSZENV7ZWWTFJD5Y.lng
T2CE542KT6BI6BASBL24PYUJQ6JTJXEN (1).lng
T2CE542KT6BI6BASBL24PYUJQ6JTJXEN.lng
I couldn’t explain it regularly, so I copied and pasted everything. Sorry for the large amount.
Biz
April 20, 2020, 7:41am
11
There was cryptBackup \ m \ WY \ AM and cryptBackup \ m \ WY \ AM (1).
Both contain a file named WYAM7YKPBIS4VOXJK6DRS6KEJOYLDKEE.lng.
Is there something wrong with this folder?
No this is how it should be. Can you please post the contents of this file?
Also, could you please post the contents of m/Q6/2D/Q62DXA4G3B7WMIF6MCHOX5HQBSBTWJ6T.lng?
Biz
April 21, 2020, 10:05am
13
Should I upload lng file?
Biz
April 21, 2020, 12:58pm
14
As insurance if the vault cannot be upgraded,
I tried creating a new vaullt instead of upgrading my existing vault. However, the same error occurred, and the vault itself could not be created in Ver1.5.0.
Maybe it’s not compatible with Drive File Stream?
You can open it in a text editor and post its content here. It will only contain a few bytes.
You can now download version 1.5.1 from here . It might help finding the error, since it has improved logging for this step of migration.
Same error is also tracked on GitHub:
opened 01:31AM - 21 Apr 20 UTC
Description
After Installing the new version 1.5.0 of cryptomator I got asked to migrate the Vault which I wanted to open. I...
type:bug
Biz
April 21, 2020, 5:24pm
18
WYAM7YKPBIS4VOXJK6DRS6KEJOYLDKEE.lng:
UP3KXE4WDITNHXRR42D7MSBPEXSQV224YS47IOGR2MEKHG2L53GN6MCCTLHR2ABEI6347TPRRD36ORYUZBD2GSATYMEYPMEYZ4OXTCPRVCPP4CPIYOC54IXER6SHRJLRGTBZ6BWUH3AQ====歹・ネw寛サx]厨"ヤF要・。KIX晄1・J?。・瀞ujワKMッユXXシフ・ア・ハZ・キツZΘ6a.ィx奴耻・區・x・+Pソア;7`GVy蕕wワXb・腥
After that, about 238 columns are garbled.
Q62DXA4G3B7WMIF6MCHOX5HQBSBTWJ6T.lng:
HPRAQJPQE6VTCN4CXQ4XX2NZ3PUKV2WDYX4N6YNLIBSFOVQJ3FUKWHWIUV7BYR77ACF3ENX5YMGQFJ63EMA5DGAQGU3KLBQKDUVF6S6H3762U4FTMW2NB6QFDPI4T4H6NZEWPVRGXJQQ====ヾBマ0el・型"aニH"8Eト璉嘉tー0
These are also garbled.
Biz
April 21, 2020, 5:25pm
19
In Ver 1.5.1, I confirmed the error log.
The upgrade.log remains the same.
The cryptomator0.log is below.
02:09:55.117 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\3YOYFCJVUP6PZDCZQ3WUNBHLQBQSPKIT.lng because inflation failed.
02:09:55.164 [App Background Thread 004] WARN o.c.c.migration.v7.MigratingVisitor - SKIP J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\Q62DXA4G3B7WMIF6MCHOX5HQBSBTWJ6T (1).lng because inflation failed.
02:09:55.169 [JavaFX Application Thread] ERROR o.c.u.m.MigrationRunController - Migration failed for technical reasons.
org.cryptomator.cryptofs.migration.v7.InvalidOldFilenameException: Can't base32-decode '6CLJNRHKBGOJNQZSYAPWI3IZFT2XE6LOTEBUV6BX2LK3PA63ONZOUW3HD2YW3RY5W5C5N7AQLIGTA7UUPHZB27N372F5WSMO4Q5YGGECV6QTFU6VGXCH4BLFC2KPFFUXLSNGFSEVCTBQ====KVPVFBM64CO7XMQGCZQPAPRTA7D7MARENVSHXD4G3UZF4===' in file J:\マイドライブ\cryptBackup\d\JS\XFUOWPIK3IS375BIG54IGU7KEK2OJU\JOT6EXTFA6UIWOH5BCU6BLXM7JMFZFPS (1).lng
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.getDecodedCiphertext(FilePathMigration.java:224)
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.getNewInflatedName(FilePathMigration.java:210)
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.migrate(FilePathMigration.java:122)
at org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory(MigratingVisitor.java:55)
at org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory(MigratingVisitor.java:17)
at java.base/java.nio.file.Files.walkFileTree(Unknown Source)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrateFileNames(Version7Migrator.java:93)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrate(Version7Migrator.java:60)
at org.cryptomator.cryptofs.migration.Migrators.migrate(Migrators.java:109)
at org.cryptomator.ui.migration.MigrationRunController.lambda$migrate$2(MigrationRunController.java:110)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:139)
Caused by: java.lang.IllegalArgumentException: com.google.common.io.BaseEncoding$DecodingException: Unrecognized character: =
at com.google.common.io.BaseEncoding.decode(BaseEncoding.java:219)
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.getDecodedCiphertext(FilePathMigration.java:222)
... 17 common frames omitted
Caused by: com.google.common.io.BaseEncoding$DecodingException: Unrecognized character: =
at com.google.common.io.BaseEncoding$Alphabet.decode(BaseEncoding.java:492)
at com.google.common.io.BaseEncoding$StandardBaseEncoding.decodeTo(BaseEncoding.java:719)
at com.google.common.io.BaseEncoding.decodeChecked(BaseEncoding.java:233)
at com.google.common.io.BaseEncoding.decode(BaseEncoding.java:217)
... 18 common frames omitted
02:09:55.169 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
02:09:55.169 [JavaFX Application Thread] DEBUG o.c.ui.launcher.AppLifecycleListener - Allow quitting without prompt: true
Biz:
WYAM7YKPBIS4VOXJK6DRS6KEJOYLDKEE.lng :
Ok first things first: This file contains things that shouldn’t be in there. I have no idea why, but it should be truncated after the ===.
