Would it be possible to create a fix all button in the future?
When I run a vault health check some vaults get shortened file names error. Ive never had a vault fail on the other options. It gives the option to fix this however, each file and subdirectory ends up with a fix button and I have to press a huge amount of them. Would it be possible in the future to add a fix all button where you could hit one button and all the fix buttons are pressed? Thank you and be safe.
