Just wondering as I haven’t seen much documentation for the current beta, what is the vault version? Usually could tell taking a look at the Masterkey, but i’m seeing “version:999” instead of the usual formats we’re used to.
A detailed description will follow but version: 999
is a hint for vault version 8 or later. If you open the vault.cryptomator
file of the vault in an text editor and decode the content of this file (which is a JSON Web Token) using e.g. https://jwt.io/ you will find out the vault format, it should look something like this
Header
"kid": "masterkeyfile:masterkey.cryptomator",
"typ": "JWT",
"alg": "HS256"
Payload
"maxFilenameLen": 220,
"format": 8,
"jti": "8f78d520-3bc3-4475-8d9f-349def87c988",
"cipherCombo": "SIV_CTRMAC"
format
is the property you’re looking for.
TLDR; Cryptomator 2.0 iOS Beta creates new vaults in vault format 8 but can also handle old formats.
