WinFsp mount as BOTH a drive AND a folder simultaneously?
Hello! I’m struggling with Cryptomator’s mount options, as I can’t seem to mount the drive in a way to get it to work with all my software at once. I use WinFsp (Local).
  • if I mount a volume as a drive letter, it lets me use WSL and other tools directly on the Cryptomator drive. But, I can’t use backup tooks like macrium.
  • if I mount as a folder and not a drive, this inverts. I can use my backup tools, but my WSL (and some other tools) fail to recognize the files.
Thoughts? I want both - I wonder if we can mount as both simultaneously, for example…
Hi. This is not possible.
As @Michael already wrote, Cryptomator cannot do that. But it is possible with Windows tools:
subst! I think the last time I used that was to spoof mounting CDs on my old Dos machine.
Thanks for the tips. After some fiddling, it seems to work really well
  • if I run subst as administrator, it doesn’t reflect my local user, run subst as a local user
  • subst isn’t persistent so needs to be re-run on boot. People looking for a permanent solution should put a startup script.
This works really well. Both the folder AND the subst mapped drive works with my backup software and everything else, where mounting as a drive directly doesn’t. Further, some programs can’t see the mapped folder (e.g., pycharm), but can see the subst drive. Great!
