gohrner
#1
Hi everyone,
I have trouble saving PDFs on a Windows 10 machine with Cryptomator 1.4.6 and (now still, after an upgrade) 1.4.15, using the Dokany driver.
The error message varies slightly, but always indicates that a write error / IO error occured.
I already found and read
as well as
but those issues were supposed to be fixed in Cryptomator 1.4.3 already.
Is it possible that I still somehow have to upgrade Dokany manually? Or is this an entirely different issue which I should open at GitHub?
infeo
#2
What is your installed Dokany version? You can find it by navigating to Settings->Apps and search for “Dokan”.
It should be at least 1.3.0.1000. If not, please download the newest version from here and install it.
gohrner
#3
Ok, it actually was 1.2.something. After upgrading to 1.3.0.1000 it works.
So Dokan(y) is not upgraded automatically when I upgrade Cryptomator?
gohrner
#5
Ok, this explains a lot, then.
Thanks!
