Hello, I am a newbie. What does “Save passwords with Windows Privacy” mean in the general settings in the Windows 11 app? I can’t select any other theme. Thank you!
It means that if you choose to store your password instead of entering it every time you u lock your vault, then this password is stored in the windows keychain.
See here: Why does Cryptomator now offer to save a pasword?
If you want to have other option, then you can use KeePassXT by installing a plugin.
https://docs.cryptomator.org/en/latest/desktop/accessing-vaults/#unlocking-a-vault
