When I disable “All devices (e.g., webcam)” permissions, Cryptomator crashes when attempting to unlock a vault stored on the local drive.
Error Code 6HCL:2GTN:615N org.cryptomator.integrations.mount.MountFailedException: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed at org.cryptomator.frontend.fuse@5.1.0/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:137) at org.cryptomator.desktop@1.18.0/org.cryptomator.common.mount.Mounter.mount(Mounter.java:172) at org.cryptomator.desktop@1.18.0/org.cryptomator.common.vaults.Vault.unlock(Vault.java:179) at org.cryptomator.desktop@1.18.0/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:109) at org.cryptomator.desktop@1.18.0/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:82) at org.cryptomator.desktop@1.18.0/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:37) at javafx.graphics@25.0.1/javafx.concurrent.Task$TaskCallable.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.run(Unknown Source) at java.base/java.util.concurrent.CompletableFuture$UniAccept.tryFire(Unknown Source) at java.base/java.util.concurrent.CompletableFuture$Completion.run(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source) Caused by: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed at org.cryptomator.jfuse.linux.amd64@0.7.3/org.cryptomator.jfuse.linux.amd64.FuseImpl.mount(FuseImpl.java:33) at org.cryptomator.jfuse.api@0.7.3/org.cryptomator.jfuse.api.Fuse.mount(Fuse.java:126) at org.cryptomator.frontend.fuse@5.1.0/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:134) ... 12 more
I have read/modify permissions granted to “All user files” and the 2nd partition where the vault resides.
Why does this app require permissions to ALL devices if I just want to use a vault on a single physical drive?
