So, here’s what I want to use Cryptomator for:
- I have a 2 TB hard disk with most of my main data.
- I just got a 5 TB hard disk to backup my data. So, I will create a few different vaults for different categories on this drive, and backup my data from the 2 TB one to this 5 TB one. I’ll use Syncbackpro to automate it, and it’ll also keep multiple versions + verify the integrity of the copied files.
- I’ll then upload these files to my IDrive personal backup, which is also of 5 TB.
The problem here is, IDrive provides its own encryption, which I don’t think can be turned off. I don’t fully trust their encryption to be zero-knowledge, and they do not encrypt file names or directory structures and hence I wanted to use cryptomator specially for those features.
However, will IDrive’s encryption mess with Cryptomator’s encryption? IDrive has two options: 1) their own server encryption, or 2) Choosing a private key. I was going to go with a private key option, but I realized that this would result in a ton of encryption on each file, and I wanted to know if that would create any problems.
I haven’t been able to test it yet, but I will test with a few small files first to know if there are any issues. If anyone has experience or can explain to me if this would be fine, or if I should not use Cryptomator for this purpose (and suggest any alternatives for file-name encryptions). And I would also appreciate it if someone could validate my backup strategy, and if it has any flaws.
Thanks!
