Using Cryptomator 1.4.6 for Linux on Linux Mint 19, I can successfully unlock a vault, but no drive window opens up, no new volumes show up… nothing. I don’t appear to have any access to my vault. Where do I find my decrypted volume?
I am using Manjaro, but i guess it should be the same.
all “decrypted” folders can be found in .Cryptomator
folder in home directory. The folder name is unfortunately not very helpful (e.g. zxHBkHzUQ9M7_0
as of v1.4.5-1, I remembered previously it was the vault name).
Thanks! I could have SWORN it automatically opened my unlocked vaults before. Anyway, I found it there, so THANKS!
Check “Reveal Drive” in “More Options” before you unlock the vault and you are back in business
Note that update 1.4.6 changes the mount point to ~/.local/share/Cryptomator/mnt
(see full changelog: https://github.com/cryptomator/cryptomator/releases/tag/1.4.6).
