Error Code 8V9J:NHA7:NHA7
org.cryptomator.cryptofs.ContentRootMissingException: The encrypted root directory of the vault D:\tomas1\cryptomator-folder.com is missing.
at org.cryptomator.cryptofs@2.4.1/org.cryptomator.cryptofs.CryptoFileSystems.checkVaultRootExistence(CryptoFileSystems.java:85)
at org.cryptomator.cryptofs@2.4.1/org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:59)
at org.cryptomator.cryptofs@2.4.1/org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:194)
at org.cryptomator.cryptofs@2.4.1/org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:86)
at org.cryptomator.cryptofs@2.4.1/org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:126)
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.Vault.createCryptoFileSystem(Vault.java:129)
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.Vault.unlock(Vault.java:148)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:72)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:62)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:35)
at javafx.graphics@18.0.1/javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
How do I get my files back?? I had to convert the file? When I reinstalled Cryptomator.
