Hi !
I’ve got a problem trying to connect the iOS app to my kDrive via webdav. I’ve set up an application password in kDrive, the connection to the kDrive is set up with this login/password, I can find the webdav connection infos in the settings.
When I try to open the vault, I select Webdav, then I see my root folder on kDrive, and when I click on the folder the app crashes. No way to access it.
I tried to create a new vault on this same kDrive, same thing : the app crashes when I click on the root folder of my drive.
Is there anything to do about this ?
