f00bar
December 30, 2022, 6:17pm
#1
my webdav box storage from cryptomator ios 2 stopped working today. i tried deleting the cloud connection and readd, received the wrong username and/or password message.
With the same credential, i was manage to connect from my mac desktop. so there’s nothing wrong with the credential and box webdav url.
Rebooted my iphone and tried again, same error message on cryptomator.
I tried adding another cloud (onedrive). no issue.
Anybody else facing same problem with box storage from cryptomator ios today?
Thank you.
Michael
December 30, 2022, 6:36pm
#2
seems like box.com ended their Webdav support years ago.
https://support.box.com/hc/en-us/articles/360052806073-Update-WebDAV-Support
I wonder how you were able to use it until now?
EDIT: Sorry, they ended only the support, but let user still use it “as long as it works”.
IMPORTANT | End-Of-Support Notice
As of October 25, 2019, Box has ended WebDAV support. If you have been using WebDAV you can continue to use it, as described in this article below. But we are no l...
my bad.
Please read point 6 in their description. maybe this helps.
f00bar
December 30, 2022, 6:50pm
#3
oh man, thank you Michael!
Did the point 6. fixed my box webdav issue. works wonderfully now on cryptomator after i login from web once.
Thanks again!
