Cryptomator don’t let me open a vault which was working pretty well in the past. My version is (for some reason) still 1.4.11 with webdav mode. Using the correct version it tells me “unlocking error. refer to log for details”.
Hereafter are the details which do not tell me anything, whats going wrong. Using another PC, an old version of the file and running cryptomator with admin rights allways gave the same result.
Who knows help to unlock this (for me important) vault? Thanks in advance for your advice.
20:04:04.693 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
java.io.IOException: Error during file system creation.
	at org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:44)
	at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:257)
	at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:88)
	at java.base/java.nio.file.FileSystems.newFileSystem(FileSystems.java:344)
	at java.base/java.nio.file.FileSystems.newFileSystem(FileSystems.java:293)
	at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:128)
	at org.cryptomator.ui.model.Vault.unlockCryptoFileSystem(Vault.java:90)
	at org.cryptomator.ui.model.Vault.lambda$getCryptoFileSystem$0(Vault.java:77)
	at java.base/java.util.concurrent.atomic.AtomicReference.updateAndGet(AtomicReference.java:209)
	at org.cryptomator.ui.model.Vault.getCryptoFileSystem(Vault.java:77)
	at org.cryptomator.ui.model.Vault.unlock(Vault.java:111)
	at org.cryptomator.ui.controllers.UnlockController.lambda$didClickUnlockButton$0(UnlockController.java:439)
Caused by: java.io.UncheckedIOException: java.nio.file.AccessDeniedException: D:\_Archiv\[...]\masterkey.cryptomator.bkup
	at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:36)
	at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.provideCryptor(CryptoFileSystemModule_ProvideCryptorFactory.java:66)
	at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.get(CryptoFileSystemModule_ProvideCryptorFactory.java:41)
	at org.cryptomator.cryptofs.CryptoFileSystemImpl_Factory.get(CryptoFileSystemImpl_Factory.java:107)
	at org.cryptomator.cryptofs.CryptoFileSystemImpl_Factory.get(CryptoFileSystemImpl_Factory.java:13)
	at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:356)
	at org.cryptomator.cryptofs.CryptoFileSystems.lambda$create$0(CryptoFileSystems.java:38)
	at java.base/java.util.concurrent.ConcurrentHashMap.compute(ConcurrentHashMap.java:1908)
	at org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:30)
	... 22 common frames omitted
Caused by: java.nio.file.AccessDeniedException: D:\_Archiv\[...]\masterkey.cryptomator.bkup
	at java.base/sun.nio.fs.WindowsException.translateToIOException(WindowsException.java:89)
	at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:103)
	at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:108)
	at java.base/sun.nio.fs.WindowsFileCopy.copy(WindowsFileCopy.java:164)
	at java.base/sun.nio.fs.WindowsFileSystemProvider.copy(WindowsFileSystemProvider.java:279)
	at java.base/java.nio.file.Files.copy(Files.java:1294)
	at org.cryptomator.cryptofs.CryptoFileSystemModule.backupMasterkeyFileIfRequired(CryptoFileSystemModule.java:42)
	at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:33)
	... 33 common frames omitted
20:04:12.590 [JavaFX Application Thread] INFO  org.cryptomator.launcher.Cryptomator - JavaFX application stopped.
20:04:12.593 [main] INFO  org.cryptomator.launcher.Cryptomator - Shutting down...
20:04:12.605 [Thread-0] INFO  o.c.launcher.CleanShutdownPerformer - Goodbye.
Summary
This text will be hidden
