Vaults are not able to be unlocked on Vision Pro. When you try to click the unlock button in the Files app the Cryptomator app opens but Unlock button is completely missing. You’re able to add the vault and everything mounts in the file app as normal. But the Face ID and unlock buttons on the Vision Pro are completely missing. I’m not sure if there’s a slight tweak you need to change in the code so that it actually shows the unlocked buttons.
