Virtual drive is no longer found
Unable to write anymore to this virtual Drive E folder… I can view all my data within but cannot add my tax info for 2025…
Not understanding what went wrong so I did a search within all Cryptomator links and came across this…
Resource type check…
Critical error: Fix state - All
C9r dir D:\Dropbox\Personal Vault\d\EZ\HYTEL4IAI4642XGP7YQ5JSUMPDYG7J\UIIJ-vK-UjHgTtHk1dR_b9ru9DIsuKS9EKm6BujYZgj8wPoRZ6KP.c9r of unknown type.
Tracked down the cause… It was the updated version of Windows Security… I have Windows 11 and the Controlled Folder Access in the Virus & Threat Protection Settings was blocking Crytomator permanently… allowing read only… I had to add it to the “Allow an app through Controlled folder access”… Have to keep the Controlled folder access on to keep back Ransomware…
