Hi been trying to find info but cannot find anything directly related to my questions.
If i have vault format 6 do i have to upgrade to 7 first or can i upgrade to vault format 8 directly.
From what i gather the 6 to 7 upgrade renames files and directories … if i do this on google drive file stream how much space do i need to have in my local cached directory for like a vault that is of 25TB size?
How long would the conversion actually take on such a large vault size? Files are in the thousands …
Also since, google limits file downloads does the renaming go into this limit and if so can you continue the migration if it fails through the upgrade process ?
Thanks. Hope this is not too much, but i do believe this are questions that could help a lot of other users as well.
You cannot skip the upgrade from 6 to 7.
This is very hard to predict. At the top of my head, these operations can happen:
- Rename file
- Create folder
- Move file into a subfolder (which was newly created)
- Read file (but only from the
m
directory, each file is just several bytes long)
In theory, only the last one should take some space in your local cached directory. So you can check how large your m
directory is.
I honestly don’t know. 25 TB vault size could be a record.
I don’t know if renaming goes into this limit. I hope not, it wouldn’t make much sense from a technical point of view. But if a migration fails, you can resume it afterwards.
Hi, just a quick update for everyone else if they have the same questions as me. I just did a complete vault upgrade from 6 to 7 (20+ vaults, largest 30TB+, 120TB+ in total). All vaults are on Google Driver and accessed through google drive file stream. I used Cryptomator 1.5.17 and eveything went without a hitch. All vaults have been successfully upgraded directly on Google Drive. Also the Conversion did take a while but a lot less than expected (largest vault around an hour). As for the migration it didn’t use any of google cache on computer, from what i gather it just renamed files.
