Vault portability (file and OS)
I’m a new user of Cryptomator and the tool seems perfectly fitting my need for file encryption. I have some questions toward the portability of a vault. For record, I will use it only locally as my cloud drive service isn’t supported (but that’s okay !).
Say that I copy the vault files on another computer with a different OS and I install Cryptomator on that OS, can I open the vault and its files with only the password I put when created the vault ?
On my current OS (Bazzite (~ Fedora)), Cryptomator has Gnome keyring as password saving option. I assume it’s for autofilling the password, but I want to make sure it doesn’t make the vault linked to a key (symmetric or not) out of the vault created by Cryptomator.
As for the recovery passphrase, can I use it on another OS from the one I initially created the vault in ?
Thanks in advance.
Yes you can
Also yes
