Vault Options does not open for an old vault [Win11]
Hi
A non-critical question, for my understanding:
I installed Cryptomator, and found that I had had a brief play with it a while ago, and had an existing vault (in pCloud). I have found the recovery key to the vault, but not the password.
From a help reference, I can see that I should be able to use vault options to recover the vault (?)
The problem is that clicking on vault options does nothing. No pop-up menu.
(It works fine on a new vault that I created)
Is this because the vault was created a long time ago and is incompatible now … or similar?
Just curious. It was only a test vault and I’m happy to remove it and delete it from my storage.
(Forgive the noob question, just learning my way around)
Thanks.
which Cryptomator version are you using? Version 1.17.0 had this bug, see Migrated vault does not display change password tab · Issue #3917 · cryptomator/cryptomator · GitHub. Solution is to upgrade to the newest version.
