Hi there! I’m running into an issue opening my vault and looking for help.
When I select my vault, I get a message saying “Your vault needs to be upgraded to a new format, before you can access it” with a button to upgrade vault. I click the button and then I see this error:
Error TB89:N6FM:N6FM
My specs:
MacBook Air running MacBook macOS Monterey version 12.0.1
Cryptomator running version 1.6.3
Hi there! I did not find anything there. Here is the text:
Error Code TB89:N6FM:N6FM
java.nio.file.NoSuchFileException: /Volumes/GoogleDrive/My Drive/<<Name of my drive>>
at java.base/sun.nio.fs.UnixCopyFile.move(Unknown Source)
at java.base/sun.nio.fs.UnixFileSystemProvider.move(Unknown Source)
at java.base/java.nio.file.Files.move(Unknown Source)
at org.cryptomator.cryptofs@2.1.1/org.cryptomator.cryptofs.migration.v7.FilePathMigration.migrate(FilePathMigration.java:139)
at org.cryptomator.cryptofs@2.1.1/org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory(MigratingVisitor.java:55)
at org.cryptomator.cryptofs@2.1.1/org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory(MigratingVisitor.java:17)
at java.base/java.nio.file.Files.walkFileTree(Unknown Source)
at org.cryptomator.cryptofs@2.1.1/org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrateFileNames(Version7Migrator.java:127)
at org.cryptomator.cryptofs@2.1.1/org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrate(Version7Migrator.java:110)
at org.cryptomator.cryptofs@2.1.1/org.cryptomator.cryptofs.migration.Migrators.migrate(Migrators.java:102)
at org.cryptomator.desktop@1.6.3/org.cryptomator.ui.migration.MigrationRunController.lambda$migrate$3(MigrationRunController.java:123)
at org.cryptomator.desktop@1.6.3/org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:140)
at javafx.graphics/javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
Looks to me like there are vault files missing or not available to cryptomator.
Please make sure all vault files are fully available. This includes the vault root folder (that is named like your vault), the masterkey file, the “d” forlder and all subfolders/files.
See also here: https://github.com/cryptomator/cryptomator/discussions/1949
It looks like you were able to solve this in your other thread? Can you give me more details on the steps you took? I’m also using GDrive to store my vault.
