Hi to all who also use 1Password under macOS.
I have created an AppleScript, with which I can log in my CM Vault’s safely. Just note that the 1Password Mini is unlocked before.
In 1Password create a login for your CM Vault (here CMDokumente) with a secure password and enter the name of your CM Vault in the AppleScript… and voilà
tell application "System Events" to tell process "1Password mini"
open location "onepassword://extension/search/XXXXXXXX"
end tell
delay 0.4
keystroke "c" using {command down, shift down}
delay 0.2
tell application "Cryptomator" to activate
delay 0.2
keystroke "v" using command down
delay 0.5
keystroke return
delay 1
tell application "Finder"
set the clipboard to " "
end tell
end tell
end tell
Here is a short Video
