So the issue is in the title: My vault is unlocked, auto-lock is disabled but still Cryptomator doesn’t appear in the files app. Any ideas?
Hi. Which iOS version?
Hey, I’m on IOS 15.0.2.
So I just updated to IOS 15.1. Unfortunately that didn’t help. Reinstalling Cryptomator also didn’t work.
Are you sure, that you installed the new Cryptomator beta app version 2.0 from Testflight (Join the Cryptomator 2 beta - TestFlight - Apple)?
Oh wait, I had no idea that it was a beta only feature till now. Then nevermind, my bad (Danke übrigens für die schnelle Antwort!)
