Using "Proton drive" on android
Currently the windows app is pretty flexible and can work with any cloud drive as long as it’s mouted. Is it somehow possible thought to use “Proton Drive” on the android app as well?
This would be a tough one because proton drive is end to end encrypted.
On other platforms like Windows. Linux, and Mac, as you know, it’s not an issue.
Currently, there are only so many remote cloud accounts available inside Cryptomator.
The only option I could think of, which was to utilize Rclone for Android as a way to open the Proton cloud account as it can on the 3 previously mentioned.
Unfortunately the developers who write the code for Windows Linux and Mac are not the same developers who write the code for Android, and at this current time there’s no support for Proton Drive in the rclone client for Android.
With proton drive you are paying a premium for cloud storage so that it can be encrypted on the proton client software all the way through to the proton cloud drive.
Cryptometer works with a handful of cloud providers in the Android software version and those cloud providers do not provide end to end encryption which is why cryptometer is needed.
My only thought and suggestion would be to switch away from proton drive to a less expensive unencrypted cloud provider that cryptometer does support on Android and do it that way.
When you store files on proton drive without cryptometer they’re supposedly already encrypted and protected from being viewed by anybody including the company so cryptomator in the proton drive world is kind of redundant and perhaps unnecessary.
Cryptometer becomes necessary when you’re operating with a cloud provider that has no encryption and looks at and scans everything that you put on the server.
Not the answer that you’re looking for only I think it’s the only one.
