Hey everyone,
I use Tresorit to sync my files. I created a Cryptomator Vault on Windows which is sync’d with Tresorit and works fine between computers, but is it possible to config Cryptomator Android to have a Vault sync’d with Tresorit? Just bought it and the options to create/add a vault are Dropbox/GDrive/OneDrive/WebDAV/Local, but no Tresorit. Is it not supported or is there a specific way to configure it?
Thanks!
