After formatting recently I re-installed cryptomater, it said I had to upgrade vault to use it… I ensured it was synced, then clicked upgrade… it said successfull, but now the drive is not unlocked or locked, its got these circles that are normally animated, but are static, refer to the picture below. If I close and re-open it, nothing changes. How do I get my data back?
Ok the fix was to remove and re-add the vault.
Cryptomator is starting to feel less open source and more commercial =(
