Floyd
#1
"Do you want to send your name and password in a way that is insecure?
The URL provided uses an unsecured method for network communication. To use a secure connection, you must use a server that supports SSL."
‘What is causing this?
It only started yesterday after yrs. of 0 problems.’
Is downloading and installing fuse still the go to option, or can I ignore this warning and proceed with connecting? The article is from 2019.
I see someone in the article stated there was no security issue due to a feedback loop.
I am non-technical.
Thank you.
infeo
Split this topic
#2
