Hello, I don’t manage to create vaults on external drive … Installed Sequoia 15.4 yesterday 2 days ago it was working.
Error Code JNLA:D3RT:81D6
org.cryptomator.integrations.mount.MountFailedException: Mounting failed
at org.cryptomator.frontend.webdav@2.0.7/org.cryptomator.frontend.webdav.mount.MacAppleScriptMounter$MountBuilderImpl.mount(MacAppleScriptMounter.java:111)
at org.cryptomator.frontend.webdav@2.0.7/org.cryptomator.frontend.webdav.mount.AbstractMountBuilder.mount(AbstractMountBuilder.java:88)
at org.cryptomator.desktop@1.15.1/org.cryptomator.common.mount.Mounter.mount(Mounter.java:172)
at org.cryptomator.desktop@1.15.1/org.cryptomator.common.vaults.Vault.unlock(Vault.java:171)
at org.cryptomator.desktop@1.15.1/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.15.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:82)
at org.cryptomator.desktop@1.15.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:37)
at javafx.graphics@23.0.1/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
Caused by: java.util.concurrent.TimeoutException
at org.cryptomator.frontend.webdav@2.0.7/org.cryptomator.frontend.webdav.mount.ProcessUtil.waitFor(ProcessUtil.java:59)
at org.cryptomator.frontend.webdav@2.0.7/org.cryptomator.frontend.webdav.mount.MacAppleScriptMounter$MountBuilderImpl.mount(MacAppleScriptMounter.java:91)
... 13 more
it seems, that another time the macOS WebDAV implementation deteriorated with an macOS update. There exists already a ticket on our issue tracker, see:
Only workaround is currently to use macFUSE or FUSE-T.
