Unfixable Errors: Directory ID reused (and files invisible, after moving folders)
hi there - I moved some folders with files in them. Now the files are no longer visible.
I ran a ‘health check’ and there are several “Unfixable Errors: Directory ID reused”
I asked GPT what to do and it is suggesting to lock vault, manually navigate to the path and delete one of them (for each ‘reused’ error).
But I’m scared I might loose data or corrupt something.
Just so we understand you are referring to moving files/folders that are encrypted and inside a Vault?
After you create a vault for your encrypted files you should not manipulate what is stored inside the vault using File Explorer from outside the vault.
I always hate to bring up this subject but is there any chance your data was backed up prior to messing with it?
It is especially important to be vigilant with doing backups of your encrypted data with the vault closed.
You should treat the root folder of the Vault as a hidden system folder that you never ever touch.
Everything in the vault was put there by Cryptomator and it needs to be treated like app data.
If you want or need to move files and folders that are in the encrypted vault you should Mount the vault and then move the files and folders using the drive letter of the unencrypted data.
Never mess with the encrypted folder structure. Treat the encrypted folder tree as part of the software. Hands off.
To Clarify:
Vault was UNLOCKED (ie mounted) and I moved folders from within W11 Explorer (exactly how you describe).
The files within them are now no longer visible.
Directory id reused means, that two directory link files point to the same directory. For you this means “opening” two different directories leads to the same directory.
Reused directory ids normally does not make single files invisible, only directories disappear.
Before any fix, ensure that the vault is synced completely and offline available.
:warning: Your vault is messed up. In order to repair it, the folder names will be lost. :warning:
  1. Make a backup of your vault
  2. Disable any sync software.
  3. Delete the parent folders of the dir.c9r files from the message. If the message says
    Directory ID reused: c155a57b-688b-4a4d-8b79-7fbdd4bc58fb found
    in C:\Users\Doobie\myVault\d\RT\6AQD5Y4CCVXXXOE3D3IZOX3KEDSA44\r69zeocbIDcndumFXnMYzpfGC8URsfi2.c9r\dir.c9r
    and C:\Users\Doobie\myVault\d\RT\6AQD5Y4CCVXXXOE3D3IZOX3KEDSA44\kODuJd7ohr_gZS8vrqzNS7tYlg==.c9r\dir.c9r
    Then delete folder r69zeocbIDcndumFXnMYzpfGC8URsfi2.c9r and kODuJd7ohr_gZS8vrqzNS7tYlg==.c9r.
  4. Rerun the health check
  5. Fix any orphan directories messages
  6. Close health check
  7. Unlock vault
  8. Inside the unlocked vault, browse through the LOST+FOUND folder. The formerly disappeared folders are shown there, but only with default names, since folder names cannot be recovered.
The fixed described did not work for me
In my case there was a duplicate folder, copied from one location to the another place which was missing important files. And any file changes within one folder, also happened to the duplicate one.
eg deleting items, creating new files.
