I cannot log into my vault. I receive the following message and am told to report it to you…
I’ve looked at the other posts on “unexpected errors”, but they are not working for me.
My IP address did change as I was having issues with my internet. That’s the only thing I can think of on my end that has changed.
Please help!
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:54)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:142)
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:51)
at org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:10)
... 12 more
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:49)
... 14 more
... 15 more
