After cloning my SSD nVME M.2 to another, larger SSD I am unable to open my vault. I receive an unexpected error. I tried uninstalling Cryptomator and Dokan Library and reinstalling but that didn’t make a difference. Thoughts?
… 11 more
… 13 more
