I tried hard to be able to use my vault on MacOS but after upgrading to 1.6.1 (dmg-3338) I’m now absolutely unable to see my only vault content when I try to add it.
I can still see the content of my vault on the iOS application.
Is there any way, from the iOS app to re-generate a masterkey.cryptomator file in order to re-open it from my laptop ?
When I use the one I have, the Personal_Data folder remains totally empty on MacOS side !!!
Hi
If you can open your vault with the iOS app, then there is a valid Masterkey file online available.
Please make sure that all vault files are synced with your Mac and fully available.
You can not recreate a Masterkey file with a mobile app.
