Hello there,
I just migrated to a new iPhone. Now for some reason I am not able to unlock my Vault on iOS.
I was using FaceID before, but even with it turned off I always get the following Error Message, after trying to unlock:
Der Vorgang konnte nicht
abgeschlossen werden.
(CryptomatorCommonCo-
re.CloudProviderAccountError-
Fehler 0.)
The Vault is on iCloud, and I can still unlock it on the Mac.
I can see that the error message could be better but it looks like that Cryptomator somehow is unable to access the folder in iCloud Drive anymore. I believe the only solution is to remove the vault in the main app and then re-add it again (it’s basically like “relinking” the vault in the app, it’s not deleting any data or anything like that). Does that work?
