Hi all, after updating my client to v 1.9.1 via flathub (Ubuntu 22.04.2 LTS) my client is not able to open my vault anymore, giving me some fuse-related error (see below). This seems to be a recurrent issue every time there is an update. The client was working normally before the update and now it is broken. The AppImage works as intended, so surely this isn’t anything related to my settings…
Error Code 6HCL:2GTN:8714
org.cryptomator.integrations.mount.MountFailedException: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at org.cryptomator.frontend.fuse@3.0.0/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:116)
at org.cryptomator.desktop@1.9.1/org.cryptomator.common.mount.Mounter.mount(Mounter.java:134)
at org.cryptomator.desktop@1.9.1/org.cryptomator.common.vaults.Vault.unlock(Vault.java:150)
at org.cryptomator.desktop@1.9.1/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.9.1/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:70)
at org.cryptomator.desktop@1.9.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:60)
at org.cryptomator.desktop@1.9.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:31)
at javafx.graphics@20.0.1/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
Caused by: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at org.cryptomator.jfuse.linux.amd64@0.5.1/org.cryptomator.jfuse.linux.amd64.FuseImpl.mount(FuseImpl.java:35)
at org.cryptomator.jfuse.api@0.5.1/org.cryptomator.jfuse.api.Fuse.mount(Fuse.java:127)
at org.cryptomator.frontend.fuse@3.0.0/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:113)
... 13 more
