Cryptomator version : 1.6.9
Volume type : FUSE
OS : Linux Mint
I succeed in opening documents after unlocking the vault, but it is impossible to save the document after modification.
In the log file, there is the following message:
ERROR o.c.frontend.fuse.ReadOnlyAdapter - release /Path/file.ods failed.
(with /Path/file.ods the path to the file)
The vault files are located on an NTFS drive in a folder synced with Nextcloud Desktop.
In the /etc/fstab file, the NTFS disk is mounted with ntfs-3g option.
This is probably a rights or permissions issue. When cryptomator is launched in a terminal with sudo cryptomator, there is no problem to save the file after modification.
Any idea how to solve this problem please?
