When having two vaults opened as directories and trying to open a third one, I just get an eror message saying details are in the log file.
This happens using version 1.4.15 (with Dokan 1.3.0.1000) on Windows 10, but I also tried a machine running Windows 7 with the same results.
Opening several vaults as drives works fine (up to five vaults so far).
Here is the log:
14:32:58.887 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.15 on Windows 10 10.0 (amd64)
14:32:59.214 [main] INFO o.c.launcher.IpcProtocolImpl - Received launch args:
14:32:59.728 [JavaFX Application Thread] INFO org.cryptomator.launcher.Cryptomator - JavaFX application started.
14:33:00.036 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded WinFunctions.dll
14:33:00.112 [JavaFX Application Thread] INFO o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
14:33:04.837 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:33:04.925 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.15, lastest version: 1.4.15
14:33:09.343 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.15, lastest version: 1.4.15
14:33:23.047 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Unable to load existing keychain file, creating new keychain.
14:33:23.945 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:33:33.692 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:33:35.193 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:33:38.858 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:33:40.682 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:33:49.667 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:33:54.666 [Background Thread 1] INFO com.dokany.java.DokanyDriver - Dokany version: 130
14:33:54.666 [Background Thread 1] INFO com.dokany.java.DokanyDriver - Dokany driver version: 400
14:34:12.718 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:34:21.055 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:34:22.610 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:34:25.338 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:34:31.240 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:34:32.252 [Background Thread 1] INFO com.dokany.java.DokanyDriver - Dokany version: 130
14:34:32.252 [Background Thread 1] INFO com.dokany.java.DokanyDriver - Dokany driver version: 400
14:35:26.267 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:35:38.081 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:35:39.233 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:35:40.528 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:35:52.439 [pool-1-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Aelg\AppData\Roaming\Cryptomator\settings.json
14:35:56.307 [Background Thread 5] INFO com.dokany.java.DokanyDriver - Dokany version: 130
14:35:56.307 [Background Thread 5] INFO com.dokany.java.DokanyDriver - Dokany driver version: 400
14:35:56.321 [Background Thread 6] WARN com.dokany.java.DokanyDriver - Error while mounting
java.lang.IllegalStateException: Mount failed: Cannot assign a drive letter or mount point. Probably already used by another volume.
at com.dokany.java.DokanyDriver.start(DokanyDriver.java:65)
14:35:56.323 [Background Thread 5] ERROR o.c.frontend.dokany.MountFactory - Mounting failed.
java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Mount failed: Cannot assign a drive letter or mount point. Probably already used by another volume.
at java.base/java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.base/java.util.concurrent.FutureTask.get(FutureTask.java:205)
at org.cryptomator.frontend.dokany.Mount.mount(Mount.java:36)
at org.cryptomator.frontend.dokany.MountFactory.mount(MountFactory.java:119)
at org.cryptomator.ui.model.DokanyVolume.mount(DokanyVolume.java:51)
at org.cryptomator.ui.model.Vault.unlock(Vault.java:115)
at org.cryptomator.ui.controllers.UnlockController.lambda$didClickUnlockButton$0(UnlockController.java:494)
Caused by: java.lang.IllegalStateException: Mount failed: Cannot assign a drive letter or mount point. Probably already used by another volume.
... 5 common frames omitted
14:35:56.323 [Background Thread 5] WARN o.cryptomator.ui.model.DokanyVolume - Failed to mount vault into C:\Daten\Sonstiges. Is this directory currently accessed by another process (e.g. Windows Explorer)?
14:35:56.325 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
org.cryptomator.ui.model.Volume$VolumeException: Unable to mount Filesystem
at org.cryptomator.ui.model.DokanyVolume.mount(DokanyVolume.java:56)
Caused by: org.cryptomator.frontend.dokany.MountFailedException: java.lang.IllegalStateException: Mount failed: Cannot assign a drive letter or mount point. Probably already used by another volume.
at org.cryptomator.frontend.dokany.MountFactory.mount(MountFactory.java:128)
... 11 common frames omitted
