I have a redundant Vault that I just can’t seem to delete using OSX Finder or a whole host of terminal commands. I also can no longer open the vault in Cryptomator, and suspect that it is now totally corrupted.
I don’t need any of the file contents as the Vault was previously duplicated elsewhere and is working fine, so I just want to be rid of this old vault.
I’d be grateful to receive on advice how to progress.
Thanks @infeo for your response. I’ve deleting the vault directory and miscellaneous sub-directories, without any success. It may be an OSX problem, but whatever it is I can’t seem to delete the vault or sub-directories. In addition to Finder I have also tried in Terminal (as self & root / sudo) with miscellaneous rm & rmdir commands; but don’t appear to get anywhere.
