Hi, I can’t drag/drop or copy pdf files to the vault. I get the following message: “the destination already has a file named xxx.pdf”. When I try to replace, I got a file with 0 ko written in the vault.
The issue onyl concerns PDF files.
Any clue? Thanks for your help
Welcome to the Cryptomator Community ,
very likely you are affected by bug "No permissions" when copy/paste into Vault · Issue #3207 · cryptomator/cryptomator · GitHub.
A new version containing a fix will be released very soon. You can already try our beta out:
Hi, I tried to download files via chrome instead of firefox, issue is still the same.
I installed 1.11 beta version and problem is fixed. Thanks !
