I have some problem when ejecting my drive. I’m using Mac OS X 10.14.4 with the Cryptomator 1.4.10 (1374). It looks like it’s giving some strange command to umount. Here is part of the log from debug mode, bug is at the bottom.
By the way, my umount is the default one in /sbin/umount.
12:40:44.400 [Thread-142] TRACE o.c.frontend.fuse.ReadOnlyAdapter - getattr /david.txt (lastModifiedTime: 2018-12-13T18:57:40Z, lastAccessTime: 2019-05-24T10:40:44.284374Z, creationTime: 2018-12-13T18:57:40Z, isRegularFile: true, isDirectory: false, isSymbolicLink: false, isOther: false, size: 6845, fileKey: (dev=1000004,ino=8602499348))
12:40:44.400 [Thread-142] TRACE o.c.f.fuse.locks.DataRLockImpl - Released read data lock for '[, david.txt]'
12:40:44.400 [Thread-142] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[, david.txt]'
12:40:44.400 [Thread-142] TRACE o.c.f.fuse.locks.PathRLockImpl - Released read path lock for '[]'
12:40:47.382 [JavaFX Application Thread] TRACE o.c.u.controllers.UnlockedController - Regular unmount failed.
org.cryptomator.ui.model.Volume$VolumeException: org.cryptomator.frontend.fuse.mount.CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: umount: illegal option -- _
usage: umount [-fv] [-t fstypelist] special | node
umount -a[fv] [-h host] [-t fstypelist]
at org.cryptomator.ui.model.FuseVolume.unmount(FuseVolume.java:141)
at org.cryptomator.ui.model.Vault.lock(Vault.java:130)
at org.cryptomator.ui.controllers.UnlockedController.lambda$regularLockVault$1(UnlockedController.java:116)
Caused by: org.cryptomator.frontend.fuse.mount.CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: umount: illegal option -- _
at org.cryptomator.frontend.fuse.mount.ProcessUtil.assertExitValue(ProcessUtil.java:26)
at org.cryptomator.frontend.fuse.mount.AbstractMount.unmount(AbstractMount.java:52)
at org.cryptomator.ui.model.FuseVolume.unmount(FuseVolume.java:138)
... 11 common frames omitted
