I configured an AWS instance so I can quickly transfer some files into a container from one place to another. Unfortunately, I cannot get Cryptomator running on Ubuntu 18, following the directions. I’ve tried both the *.AppImage and the PPA offered at ppa:sebastian-stenzel/cryptomator.
Of the errors I’ve received, this is the most recent:
21:40:19.474 [main] DEBUG org.cryptomator.common.Environment - java.library.path: /tmp/.mount_cryptoZVbiei/lib/app:/tmp/.mount_cryptoZVbiei/bin
21:40:19.477 [main] DEBUG org.cryptomator.common.Environment - user.language: en
21:40:19.478 [main] DEBUG org.cryptomator.common.Environment - user.region: null
21:40:19.478 [main] DEBUG org.cryptomator.common.Environment - logback.configurationFile: null
21:40:19.478 [main] DEBUG org.cryptomator.common.Environment - cryptomator.settingsPath: ~/.config/Cryptomator/settings.json:~/.Cryptomator/settings.json
21:40:19.478 [main] DEBUG org.cryptomator.common.Environment - cryptomator.ipcPortPath: ~/.config/Cryptomator/ipcPort.bin:~/.Cryptomator/ipcPort.bin
21:40:19.478 [main] DEBUG org.cryptomator.common.Environment - cryptomator.keychainPath: null
21:40:19.478 [main] DEBUG org.cryptomator.common.Environment - cryptomator.logDir: ~/.local/share/Cryptomator/logs
21:40:19.478 [main] DEBUG org.cryptomator.common.Environment - cryptomator.mountPointsDir: ~/.local/share/Cryptomator/mnt
21:40:19.478 [main] DEBUG org.cryptomator.common.Environment - cryptomator.minPwLength: null
21:40:19.478 [main] DEBUG org.cryptomator.common.Environment - cryptomator.buildNumber: appimage-1
21:40:19.514 [main] DEBUG org.cryptomator.common.ShutdownHook - Registered shutdown hook.
21:40:19.615 [main] DEBUG org.cryptomator.common.settings.SettingsProvider - Attempting to load settings from /home/ubuntu/.config/Cryptomator/settings.json
21:40:19.616 [main] DEBUG org.cryptomator.common.settings.SettingsProvider - Attempting to load settings from /home/ubuntu/.Cryptomator/settings.json
21:40:19.810 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.7 on Linux 5.3.0-1032-aws (amd64)
Exception in thread “main” java.lang.UnsupportedOperationException: Desktop API is not supported on the current platform
at java.desktop/java.awt.Desktop.getDesktop(Unknown Source)
at org.cryptomator.ui.launcher.UiLauncher.launch(UiLauncher.java:62)
at org.cryptomator.launcher.Cryptomator.runGuiApplication(Cryptomator.java:91)
at org.cryptomator.launcher.Cryptomator.run(Cryptomator.java:75)
at org.cryptomator.launcher.Cryptomator.main(Cryptomator.java:48)
Cryptomator Failed to launch JVM
At this point, I’m taking down my instance until I can figure out how to do this correctly. According to the directions I’ve followed, this and the *.AppImage should just work.
Thanks.
