Wie im Topic geschrieben, kann ich keine Tresore mehr entsperren.
macOS 15.0.; Cryptomator 1.14.1 (dmg-5378)
Fehlermeldung: The installed version of macFUSE is too old for the operating system. Please upgrade your macFUSE installation to one that is compatible with the currently running version of macOS.
Ich habe aber Fuse-T in der neuesten Version installiert.
Code zur Fehlermeldung:
Error Code 4VHF:Q9JM:SGVO
org.cryptomator.integrations.mount.MountFailedException: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at org.cryptomator.frontend.fuse@5.0.1/org.cryptomator.frontend.fuse.mount.MacFuseMountProvider$MacFuseMountBuilder.mount(MacFuseMountProvider.java:124)
at org.cryptomator.desktop@1.14.1/org.cryptomator.common.mount.Mounter.mount(Mounter.java:172)
at org.cryptomator.desktop@1.14.1/org.cryptomator.common.vaults.Vault.unlock(Vault.java:163)
at org.cryptomator.desktop@1.14.1/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.14.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:76)
at org.cryptomator.desktop@1.14.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:34)
at javafx.graphics@22.0.2/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
Caused by: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at org.cryptomator.jfuse.mac@0.7.0/org.cryptomator.jfuse.mac.FuseImpl.mount(FuseImpl.java:33)
at org.cryptomator.jfuse.api@0.7.0/org.cryptomator.jfuse.api.Fuse.mount(Fuse.java:126)
at org.cryptomator.frontend.fuse@5.0.1/org.cryptomator.frontend.fuse.mount.MacFuseMountProvider$MacFuseMountBuilder.mount(MacFuseMountProvider.java:121)
... 12 more
Noch ein Hinweis: Ich habe auch MacFuse installiert, da ich dies für pcloud benötige. Da ich aber Fuse-T in der neuesten Version installiert habe, denke ich, sollte dies nicht relevant sein. Bis zum Update auf macOS 15.0. hatte auch alles reibungslos funktioniert.
Grüße Phönix
