This topic is not available anymore - that should not happen !!!
The bigger problem is that nobody seems to care about the reported huge bug:
With 1.4.3. at least three people (incl. me) are not able to store any file at all. Copying files lasts very long and produces zero-byte files.
Please care about and please don’t delete this post again!
EDIT: I have to mention that I’m working on MacOS Mojave.
I am having the same problem and I’m also on MacOS Mojave. For me it looks like a WebDAV issue. In the preferences, try switching the Preferred Volume Type to FUSE. This fixed the problem for me.
FUSE is a separate install so if it’s not listed you probably don’t already have it. You can get it from here: https://osxfuse.github.io/
Once installed you should see the extra option in Cryptomator preferences. You can switch from WebDAV to FUSE without needing to change anything about your vaults.
sorry, it seems I got you wrong as I expected this switch option as an internal function of Cryptomator
Up to now I had no need to install Fuse and even Cryptomator worked without it until 1.4.2 except one little other problem:
Every time I start Cryptomator I get an Internal Error Message (in German) “Eine nicht abgefangene Ausnahme ist aufgetreten…”.
Unfortunately I’m not a Cryptomator developer so I can’t help with that message. I’ve always had FUSE on my system as I use it for other things and it fixed this issue for me.
It’s clearly a problem with 1.4.3 and hopefully the devs will fix it soon.
I just looked into the moderation history and saw that “system” deleted the thread. Apparently this is due to the fact that the OP deleted his/her account. I’m sorry if that caused confusion but I can assure you that it is not our intend to cover a bug. As you can see in the GitHub repo we’ve always publicly documented bugs, even in the early times when there were some security fixes.
