I do not know if there was this request before. unfortunately my english is very bad.
it is possible to create multiple vaults in the file system of windows or linux and then all can be synchronized with a cloud.
I would like to maintain my file structure largely and not everything in a folder.
Thank you
You can create as many vaults as you like. But you can also build your file structure in one vault, because a vault “works” like a hard disk. It’s your choice.
