I recently started using Cryptomator, and was so impressed I bought a license key. I have been using my vaults with no isse for a week or so, but today whenever I tried to open any vault I got the following error:
org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 53 has occurred.
The network path was not found.
at org.cryptomator.common.vaults.WebDavVolume.mountServlet(WebDavVolume.java:86)
at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:48)
Caused by: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 53 has occurred.
at org.cryptomator.common.vaults.WebDavVolume.mountServlet(WebDavVolume.java:84)
... 12 more
This was on 1.5.14 (exe-2794.223) but the issue remained after upgrading to the newest version today.
This error also happens when I create a new vault and try to unlock it.
